Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Paints for a Front grille spray
    Woodbridge
    Default Paints for a Front grille spray
    Hi, I seem to have caught the Mod bug lol.
    My first project will be quite a simple one, it is gonna be the front grill on a preface lift vectra.
    I dont want to buy one as I want to keep the vauxhall badge, I am thinking of spraying the V on the grille to colour code it with my car, but keep the badge silver.
    Could you give me some tips on the paints to use as I have no idea what to use. I want the final finish to be a nice shiny black sapphire.
    Thanks.
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    i will be watching this 1 as im going to do the same
    Oct 2007
    Shropshire
    For the paints if you just go to Halfords you will be fine.
    For tips on doing it I can't stress the importance of preparation. Out of all the time you spend 99% will be rubbing down and 1% spraying.
    Woodbridge
    So do you suggest, rubbing down, priming, colour then lacquer?
    Regular Member gibbon7000's Avatar
    lincs
    Sounds about right, get plastic primer tho, and some tack cloths.
    Woodbridge
    cheers gibbon. This may sound stupid but what grade paper do I need, I am guessing a really fine one.
    I have never done this before but you live and learn I guess.
    lincs
    for keying, 600 will be ok, then you want 1200/1500 for flatting.
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    This mod cost me £60!!! didnt prep for long enough, did it outside, couldnt get the spray round the griffin as i wished, ended up with a right abortion!!!! had to go to straight to dealer and get a new sri grille £59! Ive sprayed wing mirrors before excellent like a pro job, but this grille was a terrible idea. as mentioned prep is cheaper than the cure! make sure you deffo want this mod, and even consider getting a grille of ebay to practice on.
    Woodbridge
    Is it really that bad? Hmmmm, having second thoughts, I have never done anything like this.
    Oct 2007
    Shropshire
    The paint does not stick to the chrome you have to take it ALL OFF. EVERY SINGLE BIT!
    I would start with a 300grit to get the chrome off then 600 then 800 wet and dry. Then primer it and rub it down again with a 1200 or 1500grit. Allow it to fully cure first.
    Then spray the base and build up the layers rubbing down in between if necessary. Finally before you spray the laquer rub down with 2000 grit. Black is hard to spray because you sort of see straight through it! Then apply the laquer rubbing down between each coat. Then wax and polishing it up to a shine.....
    AS I say take the chrome off first...
  1. Spray painting front bumper
    By dti owner in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 13:18
  2. Where best to get spray paints?
    By ronnie63 in forum Bodywork & Interior
    Last Post: 26th May 2009, 17:42
  3. Front Splitter Spray Painting !
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2009, 19:23
  4. New Bumper, And Front End Re-Spray
    By Mark The Cabby in forum Styling
    Last Post: 26th October 2006, 08:26
vectra c spray front grill
