Results 1 to 3 of 3
Thread: fault code for alternator problems
    Regular Member mace's Avatar
    Jan 2008
    Wiltshire
    Question fault code for alternator problems
    Does anyone know if a failing alternator would log any fault codes? Car behaving strangely today symptoms are:
    hgh idle rpm - 1100
    lights blink when cranking starter
    fan only blows at full power when car under load, if coasting it stops
    any ideas? it's a 150CDTI estate 2007
    cheers
    Regular Member djr69uk's Avatar
    Midlands
    sounds like alternator or battery mate. winter puts a tremendous strain on both. pop into your local kwik fit or nationwide autocentre and they will strap an expensive looking gadget across your battery terminals and tell you for sure.
    Jan 2008
    Wiltshire
    Popped to supermarket this evening and the blasted thing wouldn't start when I came out. Breakdown man turned up in 5 mins flat and got her going again, he confirmed it was the alternator on its last legs. I drove the mile home and the power steering, lights etc died just as I pulled onto the drive!
    Big thumbs up for Greenmeadow Breakdown
    Have yo ring round tomorrow for quotes but I hear 350 - 550 fitted is the ballpark figure
  1. 150 Diesel fault code problems
    By dannycturbo in forum Engine & Drivetrain
    Last Post: 25th January 2012, 14:46
  2. alternator problems
    By tyler boy in forum Electrical & ICE (including SatNav)
    Last Post: 10th November 2011, 19:19
  3. P1109 fault code after alternator replacment
    By knfruitbat in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2010, 21:05
  4. Fault Code Problems....
    By t9taz in forum Vectra C / Signum Troubleshooting
    Last Post: 10th October 2009, 16:42
  5. Alternator fault
    By RCP1 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th January 2008, 13:48
vectra c faulty alternator symptoms
vectra c alternator complaints
opel vectra C alternator code
vectra c alternator faults
vauxhall vectra c alternator fault code
