Results 1 to 8 of 8
Thread: Another one with dull response
    Jan 2011
    York
    Angry Another one with dull response
    Iv read through post after post on this topic but don't think this one has been covered.
    I have a 1.9cdti 150 55 plate vectra and it's developed a dull/dead response before the turbo kicks in. No dash lights have come on nothing to suggest the reason for it's poor running.
    Iv had the EGR valve off (well caked up) and cleaned all that out, Iv blasted redex through her, de coked as much as I can pull off it. The actuator arm moves fine for the swirl valves, well I think it does. My question is: through how many degrees (ish) can you see the top of the swirl valve move when everything is ok?
    Iv read somewhere that the module "learns" to addapt one way but can reverse. So if this is the case and my swirl valves are caked up has it learnt to stop the valve before it jams/settles in the carbon build up? As a result there isn't sufficient air flow past the valve because it is so caked up but from the outside the swirl valve seems to be working correctly.
    I hope that made some kind of sense to you all I also hope you can help before I take a lump hammer to it.
    Bov
    Mar 2010
    Trim : Design
    Engine : 1.9 CDTi
    Clean the boost sensor first as that made most of the difference on mine.
    Mar 2010
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    What's actually happening, is it rolling up to junction/roundabout, put foot down gently and nothing happens? Then turbo kicks in? I had that when I first had mine, assumed it was an autobox thing. The airbox mod and a K & N helped.
    Jan 2011
    York
    In neutral, first, second and so on put your foot on the accelerator and the climb up to the turbo kicking in is really really slow. After cleaning the the valve out the response when the turbo kicks in it much better but no change to pee turbo. In second gear with your foot flat to the floor I could run faster until the turbo kicks in. This is not normal as the car never used to do it, I don't want to mod around the problem I'd like to try and fix it, but it's an idea.
    Sep 2009
    middlesbrough
    Has the rod come off the back of the manifold? Also when you cleaned the egr valve did you make sure the plunger was moving freely?
    Jan 2011
    York
    Nup it's still attached and yep the plunger is free as a bird, I bathed it in brake cleaner and scrubbed with a tooth brush...good as new.
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    i had a similar problem in the end a new egr valve cured it
    Regular Member Aikon58's Avatar
    Feb 2010
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    I've just unplugged my egr valve for now.
  1. Another one with dull response
    By Bova2k in forum Vectra C / Signum Car Chat
    Last Post: 25th January 2011, 18:22
  2. probably a dull question but hey hoe
    By myelite150 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2010, 15:57
  3. Dull knocking
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 25th September 2010, 18:33
  4. dull headlights
    By lynnie in forum Vectra C / Signum Troubleshooting
    Last Post: 1st March 2009, 17:40
  5. Dull paint
    By Big Sig in forum Detailing and Car Care Discussion
    Last Post: 13th October 2008, 21:24
