Results 1 to 10 of 13
Thread: Torx screws in wheel arches !
    Regular Member monkeez's Avatar
    Apr 2008
    North East
    Default Torx screws in wheel arches !
    I need to remove my front bumper but 3 of the four torx screws in the front wheel arches wont budge !
    I've tried the next size up torx bit - no luck, and i've soaked them in WD40 - still no luck.
    Any ideas? or do i have to drill them out?
    Administrator plasma's Avatar
    On the Forum
    556 Post(s)
    Engine : 150
    Mileage : 74000
    If they are screwed into the wheel arch liner then remove that as well as one piece with the bumper, had to do that to someones car on here lol..... Then I used a chisel to cut through it and remove.
    Apr 2008
    North East
    cheers, there's nowt simple is there
    13 Post(s)
    Can't see how they are seized. When I removed my bumper the torx screws in the wheel arch were screwed into plastic.
    Also you'll need to remove the top bolt to release the locking mechanism that holds the bumper to the wing - if it's a facelift.
    Apr 2008
    North East
    i've put the t20 bit in but no joy, they just wont turn.
    it's a pre-facelift mate
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    I Had Same Prob..I Had To Grind Them Out Then Go 2 Stealers And Buy New Screws And Red Plastic Nuts
    13 Post(s)
    Quote Originally Posted by monkeez View Post
    Have you tried tightening them slightly before undoing?
    An old trick for rusted bolts.
    Regular Member mxt's Avatar
    Nov 2010
    J17 M6 Sandbach, Cheshire.
    This technique has got me out of several times hacksawing bolts - which is what I used to have to do before I accidentally discovered it.
    Apr 2008
    North East
    good call, i'll try that tonight
    Edinburgh
    I had this and used my dremel to remove them
  1. Torx screws!
    By larrysSRI in forum Bodywork & Interior
    Last Post: 19th April 2012, 15:57
  2. Torx screws on coil pack.
    By ridgers84 in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2012, 22:19
  3. Airbox Torx screws - all 5 vital?
    By RykuZ0 in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2007, 11:00
why doesnt tork screw tighten into my bumper
seized wheel arch screws
vectra c bumper torx screw
vauxhall vectra wheel arch screw
vauxhall interior t20 torx screws
