Results 1 to 10 of 19
Thread: Rear lil window removal?
    Regular Member 2ltrT's Avatar
    North-East (Middlesbrough)
    Default Rear lil window removal?
    how is the lil back window removed?
    Plasma and i have just done spikeys..it goes like this...
    remove the inside boot trim..pop studs
    remove the side shelf support but watch the wires for the canbus that are behind.there are TORX fittings all over the place including behind the rear seat side bolsters.the white trim is held in with some feirce clips.
    This then reveals the fixings..the 1/4 window is held in with 9mm plastic nuts fitted to screws on the frame.
    Regular Member Harry's Avatar
    Uxbridge, London
    mark's above description is how you are MEANT to remove the window.
    mark found the easiest/quickest way to remove Spikey's rear quarter window was a large metallic device such as a crowbar and yank that mother out!!!!
    ROFLMAO...
    cheers... how about the door trims (chrome)? i presume just strong clips, but is there any techniques?
    Uxbridge, London
    the chrome trims on the rear quarter glass is actually bonded to it, so you can't separate unfortunately
    Quote Originally Posted by Harry
    aye... i'm thinking of replacing my none chrome trims with chrome trims... so i also need to know how to remove the front & rear door trims.
    mick,
    the front and rear trims just prise up off a flange on the top of the doorskin..they take about 20 seconds each to remove..start from the edge with the vinyl trim on and just lift up..
    Hertfordshire
    Yep, and dont forget the nail gun for the re-fit...
    it's holding it in there well!!!
  1. rear door window removal
    By Al 22 dti in forum Bodywork & Interior
    Last Post: 30th April 2011, 20:54
  2. Removal/re-fit rear window vectra c?
    By Dean in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2010, 15:50
  3. B pillar & rear window trim removal
    By sithompson in forum Bodywork & Interior
    Last Post: 12th June 2009, 21:45
  4. Rear Window handle removal.
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2007, 00:56
vectra c rear window removal
