Thread: bonnet catch
    Regular Member kristian's Avatar
    nottingham
    Year : 2002
    Mileage : 175000
    Default bonnet catch
    my bonnet wont pop any more , the leaver part works (even though its a bit slack) but the spring does not seem to push it up (so it takes 2 to open it ) is this a common fault or is it just mine
    Essex
    28 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    it might need adjusting and some lube in the hole (OOERRRR MISSUS)
    Regular Member i5aces's Avatar
    andover
    could be worse mate mine has snapped away from the cable and i need pliers to open it
    nottingham
    Year : 2002
    Mileage : 175000
    oh no i lubed it all up and cleaned every thing its as if the spring has lost its boing lol
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    maybe too slack? i tightened mine up the other day in fear of this!
    Regular Member sheepish's Avatar
    Yorkshire
    Mine was pretty dodgy like you're describing but it turned out to be the catch holding onto the thing on the bonnet making it feel like there was no 'pop' when you pulled the lever (I used to have to pull the bonnet up while the lever was operated). Lubing did the trick though, I got 'Er Indoors to pull the lever repeatedly while I sprayed it with WD40 and in no time it was sorted.
    ...worth a try.
    Cumbria
    Default Bonnet Catch
    If there is slack in the cable then it needs adjusting by loosening the screw that holds the outer cable to the slam panel. Slide the outer cable towards the battery side just enough to remove the slack, usually about 15mm. Then retighten the screw as tight as it was to undo it. Do it asap or the cable will fall out of the spring and then you are snookered.
    Regular Member leonvectrac's Avatar
    south shields
    do you need to remove bumper to adjust the cable? mine needs doing but wana find out exactly how to do it before i open it, as it is ready to just go all together.
    Cumbria
    No it's really easy. Just open the bonnet and its on the engine side of the slam panel. It is a three minute job and if you don't do it, it becomes a three hour + job.
  1. Bonnet catch...
    By david.aka.judas in forum Bodywork & Interior
    Last Post: 5th April 2010, 20:16
  2. help with bonnet catch
    By SRimonkey in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2009, 21:51
  3. bonnet catch
    By scriv in forum Vectra C / Signum Troubleshooting
    Last Post: 7th January 2009, 12:10
  4. Bonnet Catch
    By AndrewTi in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2008, 07:58
  5. Bonnet catch
    By Marc 100 in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2006, 10:11
