Thread: coolant level
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    Default coolant level
    is it normal after doing a coolant change or when you do that like changing stat that when you refill the coolant and it all up to the right level, but when you check after the engine is cold its about 1inch below max is that normal?
    Mileage : 000
    It could have been an air lock somewhere and running the engine it has removed the air lock, thus now the fluid level has dropped.
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    cheers bit worry because one of the blts on the stat housing didnt tighten as good think its rounding off but ive checked for leaks and it seems dry around that area, ill top it up tomorrow when engine is cold , doing a 120 mile trip tomorrow so ill find out then if i have any problems
    Regular Member sheepish's Avatar
    Yorkshire
    When I had the cam belt and water pump replaced and when I replaced the thermostat I had the same both times. Just top it up and keep an eye on it for a few days, I'm sure you'll find it's all ok...
    Regular Member djr69uk's Avatar
    Midlands
    perfectly normal. i changed mine and the level was fine when i left it and went to bed. the next morning it had dropped again!
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    tis totally normal fella the level will always drop when the car is cold thats why they tell you to check it when its cold and has a cold level on the expansion tank
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Yup perfectly normal, may take a couple of days to settle down as all the air bleeds out the system.
  1. Coolant level etc
    By SlowCoach in forum Vectra C / Signum Troubleshooting
    Last Post: 12th October 2012, 11:50
  2. Coolant level?
    By Chunklamb in forum Engine & Drivetrain
    Last Post: 23rd July 2012, 20:38
  3. coolant level icon
    By johnboyab in forum Electrical & ICE (including SatNav)
    Last Post: 3rd April 2012, 19:57
  4. Coolant level?
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2010, 05:32
  5. Coolant Level Switch
    By sjanisz in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2006, 16:09
