Thread: mil control circuit malfunction code PO650 ( no dash warning light on car)
    essex
    Default mil control circuit malfunction code PO650 ( no dash warning light on car)
    Guys it seems my car has had the mil control light on the dash removed from the car somehow to mask up the egr fault on the car before i bought it This would explain why i didnt find out the egr system was removed from the car till i did a obd2 check which revealed it!
    Wondered if anyone knew how the dash warning light was killed off???
    I have been advised that the bulb is hardwired in so cannot be removed! Is this right??? I wondered if it could be removed via programing somehow as i know the car was mapped sometime in the past but have no history of how!
    Cheers rich
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    As per my PM, I beliebe this has been disabled - either physically or via the OBD port. The reason is to hide the fact that the EGR system has been physically removed from the car.
    The long in short of it m8 - He took the bulb out of the EML symbol hence it's not being disaplayed but there is an EGR valve related fault code stored.
    Gazza4
    essex
    Nice one gazza, only posted this after pm to find out if theres a particular method goin around to disable it! Didnt want to remove the clocks to check for a removed bulb if there isnt a bulb there to remove. After hearing that the bulb might not be removable i thought it would be worth finding out if this was true before pulling the dash apart ..
    the code does say " damaged circuit so i wondered if there was a way of shorting it from somewere on the loom or something!
    Cheers for all the help on this gazza, most helpfull indeed..
    Engine : 1.9 CDTi
    Probably just cut the track or cut the wire at the back of dash.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by richiem View Post
    No problem m8.
    Gazza4
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It's maybe not removed or shorted, black tape can do amazing things
  1. P0650 mil control circuit malfunction code
    By bobsimes in forum Vectra C / Signum Troubleshooting
    Last Post: 15th May 2018, 14:41
  2. Replies: 2
    Last Post: 24th June 2012, 02:11
  3. P0621 - Generator Lamp "L" Control Circuit Malfunction
    By danielk in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2012, 20:57
  4. p0480 fault code cooling fan 1 circuit malfunction
    By Miketwinny in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2011, 22:31
  5. O2 Sensor Circuit Malfunction
    By marcdale in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2009, 21:21
