Thread: bumper keeps popping out
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    Default bumper keeps popping out
    As titled the front bumper keeps popping out at the side of the headlight where it meets the wing...how do I sort it? I had the bumper off to do the hids. It doesn't seem to pop back into place, I didn't really have a good look, can the clips on the car be ajusted or replaced?
    thanks guys
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    BTTT thanks lol
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Might just need the bracket thing replacing that the bumper pushes into, not a lot of cash to replace though.
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Had this today when we put my bumper back on. Just put that side on first and make sure it clips, its easier if the whole thing isn't in place, then do the other side. had to push it a bit but it stayed eventually. or as above replace the clip bit
    13 Post(s)
    The top bolt in the wheel arch locks it into place. Make sure before reattaching the bumper to the wing that the locking slider is pushed fully forward (put the top bolt in the hole on a couple of threads and push as far forward as you can). Offer up bumper to wing and align correctly then do up the top bolt - which will pull the slider into place and should lock the bumper into position.
  1. NIGHTMARE - Popping out of 5th gear
    By UncleMelon in forum Engine & Drivetrain
    Last Post: 12th May 2012, 16:09
  2. Front bumper- popping off!
    By Reevo in forum Bodywork & Interior
    Last Post: 29th November 2010, 22:04
  3. Just Popping in.......
    By signum_1.9 in forum The 'Off Topic' room
    Last Post: 27th August 2010, 09:11
  4. Signum popping sound
    By GaryJ in forum Suspension, Wheels & Brakes
    Last Post: 12th December 2006, 21:20
