Thread: hard, grinding, weird brake pedal
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default hard, grinding, weird brake pedal
    Right have gone to the shops and gave the car some vent but have noticed when i do my brake pedal goes all funny???? Either goes ROCK SOLID! then as u press it when your slowing down it kinda melts back to normal. Or when you press it you get a grinding sensation? like abs but as mine isnt working for someknown reason without anywarning lights. but doing 65mph surely its cant be that? but driving normally it all fine now was going to get it checked soon but has anyone got any ideas? or possible big bill bad news I know its not pads or disks as there are all brand new. Just a little worried as the wife use's it for the school run and wondering if it could be dangerous. Cheers in advance
    Nov 2010
    BRECHIN
    Think ive found the problem. The pipe that comes from the brake servo to the top right hand side of the engine, looks like it has been snapped off and someone has tryed fixed it with black electrical tape! not good! is this going to be safe to drive until I get a replacement?
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    I would say anything with brakes is asking for it mate, just my opinion. I wouldn't drive it until it was sorted
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    not advisable tim if you are involved in an accident a police engineer report will find the fault and your insurance is void,the braking effort is greatly reduced when the servo is inoperative,when you replace hose check that the non return valve is working,
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Don't drive the car. You will endanger other road users as well as yourself.
    Gazza4
    Nov 2010
    BRECHIN
    cheers for that guys, wife wont be happy bout that. but safety first. where is the non return valve. i bought the car from a garage as well! surly its against the law to sell a car with such a fault!
    Jul 2009
    Engine : 20 Dti
    it's in the vacuum line just above the bend on the engine end of the pipe
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    it most of bein like that since you got it and you have bein driveing it like that for how ever long you had the car so one more day with a like fix to make it how it was would be fine just drive slow and get it fixed asap
    Nov 2010
    BRECHIN
    problem solved! the pipe that joins to the clip that goes to the manifold side of the pipe was totally broke off and fixed up with what looked like superglue and then rapped in black tape to cover it up. so whet to fiskins of forfar to get a replacment servo hose. no chance i was told. you can have this instead bit of rubbery pipe so removed end from manifold and removed end from non return valve. replaced with rubbery pipe from fiskins "FREE OF CHARGE" man dealer too! not figured that bit out yet either!!!! attached it to non return valve and manifold with 2 53 pence jubilee clips from local motor factors and the jobs a good unn!!!! WE HAVE BREAKS AGAIN! cheers guys!
  1. For Sale: Vauxhall Insignia Brake Pedal Alloy Cover - SRI sports pedal cover
    Last Post: 20th December 2012, 21:36
  2. clutch pedal feels weird
    By abz123 in forum Engine & Drivetrain
    Last Post: 2nd April 2012, 21:05
  3. hard brake pedal
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2012, 19:42
  4. Weird flutter linked to brake pedal?!?!
    By s2yob in forum Engine & Drivetrain
    Last Post: 22nd November 2011, 20:26
  5. grinding rear brake
    By langers306 in forum Suspension, Wheels & Brakes
    Last Post: 21st February 2009, 17:28
vectra c cdti hard brake pedal
