Thread: power steering pump???
    Jul 2010
    folkestone
    Default power steering pump???
    hi all looking for some help here i posted a few weeks back about my steering packing up after having a car wash, checked everything(fuses,connections,fluid level) too no avail then read a post about alternator not charging so charged the battery and hey presto it worked so i fitted a new alternator but the problem has returned one time it works then it doesnt and so on sometimes it fires up while driving and works till i shut off the engine and on restart it fails again lol.
    the strange thing is i have NO WARNING LIGHT so am kinda thinking it has too be a faulty pump???? i did read a post somewhere about removing a spring in the check valve in the pump/rack.
    the car is an 03 gsi any help would be much appreciated
    Jul 2010
    folkestone
    anyone please
    Jul 2010
    folkestone
    Helppppp lol
    Jul 2010
    folkestone
    anyone got any ideas??
    Regular Member lee1828's Avatar
    Jan 2010
    stockton on tees
    its possible water may have gotten in the pump? have you checked the colour of the power steering fluid also? may have water in that. Not sure about the battery/alternator thing though
    Jul 2010
    folkestone
    Cheers lee if it is water in the pump could that fool the ecu into thinking it's working when it isn't hence the no warning lamp?? I suspect it is water related just don't get why it's not coming up as a fault. The fluid is clean and there is no wAter contamination it's green and was changed 10k or so ago
    Jan 2010
    stockton on tees
    to be honest mate im not sure, its just you say it happened when you came out of the car wash, so was thinking water has got into the wrong place Did you say your power steering fluid is green??
  1. Power steering pump
    By viper8 in forum Engine & Drivetrain
    Last Post: 26th January 2013, 23:25
  2. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  3. Power Steering Pump
    By andrewduffy21 in forum Engine & Drivetrain
    Last Post: 20th March 2012, 15:32
  4. Power steering pump
    By monkeydribble in forum Troubleshooting
    Last Post: 7th December 2009, 18:28
  5. 3.0 DTI Power Steering Pump
    By minky350 in forum Engine & Drivetrain
    Last Post: 7th November 2009, 16:34
