Thread: CDTi 150 Airbox hose?
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default CDTi 150 Airbox hose?
    Was fitting the HID's to the main beam today and noticed there was a small hole in the airbox and a rubber pipe not attached to it but hanging loose. What is this pipe, where does it go / come from and what would happen if it was not attached?
    north east
    Im probably wrong but i think its a drain incase water gets in.
    Tain - Easter Ross
    I would think if it is a drain it would be on the bottom. Should have said but its on the side towards the bottom on the engine side, not the wing side.
    stockport
    Arrow
    Quote Originally Posted by RobW View Post
    It is a drain hole and the "funny" shaped tubing,fits onto an open pipe,way down past/in amongst,the air con pipes you can see by the side of the air box.(It's piggin awkward to fit on),so most people leave it loose to drain away to it's hearts content,(if you ever get any water in your air box that is!!). FELIXX.
  1. Air inlet hose size (airbox)
    By cont1204 in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2012, 19:30
  2. Rubber hose on the underside of the airbox ?
    By VecPower in forum Engine & Drivetrain
    Last Post: 3rd February 2012, 13:56
  3. Strange hose near airbox - should it be connected
    By markluk in forum Engine & Drivetrain
    Last Post: 18th July 2010, 22:36
  4. 3.2 GSi airbox hose diameter
    By Tennants in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 20:53
  5. airbox hose
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2010, 23:56
vectra c hose at bottom of air box
vectra rubber hose on air box
