Thread: window washer jets not working
    wolverhampton
    Default window washer jets not working
    i have taken out the main pump in the bottle on my signum and dropped it into a jug of water and the jets work fine so tht elimates a blocked pipe problem and problems with the pump i have taken the bottle out to see if there was anyfin blockin the pump and there wasn't havin put everthing back to together and fitted it bck to the car washers jets still arnt working could this be a problem with the washer bottle itself or a problem with the rubber seals for the pump and water level bobbing
    Regular Member kdadidog's Avatar
    county durham (peterlee)
    i had this problem after the winter and it was the filter on the end of the pump. Have you checked that. Mine works better than ever now after I cleaned that. All I got before hand was the pump noise but no water coming out.
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    clean the filter out bud cos you probably left it in the washer tank
    wolverhampton
    thanks as allways guys it was the filter all sorted now .........
  1. washer jets -NOT WORKING!
    By nim-nim in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2011, 18:52
  2. Blooming Window Washer Jets
    By sjboyington in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 20:56
  3. Intermediate wipers and washer jets not working
    By R2XPT in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 23:12
  4. Washer pump working not the jets
    By JACKALG1 in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2010, 18:28
  5. Washer jets not working on 2.2dti
    By jazzy_2.2dti in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2006, 08:38
vectra washer jets not working
vectra c window washers not working
vectra c washer pump fuse
Washer jets blocked on vectra c front
