Results 1 to 10 of 17
Thread: Towbar electrics wiring?
    Oct 2010
    Lincoln
    Default Towbar electrics wiring?
    Previous owner had the towbar removed and simply chopped the wiring to
    the 2 sockets and left it taped under the bumper
    It's connected to the rear fuse box so I would like to use this rather than scotch to the rear light clusters. Does anyone have or know where I can get the wiring diagram so I can reconnect it? I have Opcom so I can put it back into 'towbar present'.
    Apologies if this is the wrong forum?
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Wiring In mines Is
    1.Yellow
    2.Blue
    3.White
    4.Green
    5.Brown
    6.Red
    7.Black
    This What You Need ?
    Mines Is Single Socket Mind You
    Oct 2010
    Lincoln
    Is that connected directly from the rear fuse box?
    I can sort the other socket using a relay.
    Aug 2010
    Dundee-Motherwell
    Thats A Good Question That Is lol
    I Only Know The Colour/Numbers As I Had To Re-New My Backing Plate On My Tow Bar As It Was Rotten
    If No Other Replies Will Check Shortly M8 When I Go Out
    Oct 2010
    Lincoln
    OK thanks, I have a 7 way bypass relay ready but if I could use the cables already there then I get the indicator warning on the dash when the van lights are working rather than a buzzer in the boot!!
    Aug 2010
    Dundee-Motherwell
    From What I Can See Mate It Is Coming Straight From The Fusebox..Loads O Wires Behind That Fusebox Panel
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Hi mate, if you look in the boot of your car near the spare wheel, do you have a black plug fastened to the back?
    This is normally where the towbar would plug into the rear loom, if you look behind the panel where the rear fuse box is, is there a connector plugged into the bottom right, as circled in the picture (it may have more wires in the plug)?
    If so the pins are below for the plug in the spare wheel well are:-
    Function Wire colour Pin
    left turn blk-white 1
    right turn blk-grn 4
    Battery +ve red 8
    left park light grey-blk 9
    right park light grey-red 12
    trailer brake light blk-yel 3
    trailer reverse light white-blk 2
    trailer fog light blk-blue 11
    Plug diagram also below.
    Oct 2010
    Lincoln
    Have to give up on this one and put the 7 way bypass in instead. I need the security code to Opcom it back in and I never got that with the car
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by lee_umney View Post
    Battery +ve red 8
    Thats only if the auto folding towbar is fitted iirc. The normal towbars by pass that wiring and plug straight into the multiplug
    Oct 2010
    Lincoln
    The wiring on mine plugs into 2 multipin sockets at the end of the fuse box nearest the rear of the car.
  1. Reverse wiring for black towbar electrics,
    By SlowCoach in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2012, 02:20
  2. Vectra C towbar electrics/Relay wiring
    By canny03 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd March 2012, 01:31
  3. Towbar electrics
    By jofenan in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 16:21
  4. Towbar electrics
    By CPHB in forum Electrical & ICE (including SatNav)
    Last Post: 14th July 2005, 21:28
vauxhall vectra c towbar wiring diagram
vauxhall signum towbar wiring diagram
vectra c towbar wiring plugvauxhall vectra towbar electricshow to wire vauxhall signum towbarvectra ctowbar wiringwiring tow bar vectravauxhall vectra towbar wiring diagramhttps:www.vectra-c.comforumshowthread.php127501-Towbar-electrics-wiringhow to wire up a towbar on a Vauxhall Vectra Cvectra c tow bar electrics wiring diagramtowbar plug on signumVauxhaul vectra tail light wire colourtowbar fuse vectra cremove tow bar and fog light dont work on vauxhall insigniawiring vectra c towbarvectra c trailer fuseboard connectorvectra rear light for towbarsvectra c towbar electric plugvauxhall omega factory towbar wiring plugvectra c wiring box for towbartowbar wiringvectra c boot fuse box wiring
