Results 1 to 10 of 16
Thread: Can you believe this car?
    Nr Cardiff
    Default Can you believe this car?
    Had my Siggy back Saturday after the following has finally been replaced;
    Turbo, intercooler, intercooler pipes, catalyst, EGR valve, wastegate & actuator, fuel pump, injectors, fuel lines, throttle valve (?), mass flow sensor.
    Driving home from Cornwall today, I get the spanner light again and this time I loose 1st, 3rd and 4th gears in either auto or tiptronic.
    In full auto it stuck in 5th, the only way I could get 2nd to pull away from the Tolls was to use tiptronic and select 2nd.
    Rang Hutchins, back in to the garage again . To add insult to injury I stopped at the services for a pee and the bl00dy thing cleared itself. The spanner was showiing on the dash for a good hour though, so hopefully it should have stored a code for them.
    Interestingly enough, when the service manager spoke to Vx, they suggested a couple of things immediately although he won't confirm what they are until the get a chance to see it themselves.
    Anyone want to hazard a guess?
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Like he said !!!!!
    Regular Member S888 SRB's Avatar
    May 2006
    Hemel Hempstead, Herts
    yep definately a lemon.
    I'm sorry to hear you are having these problems...
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    lol at john but hope you get it sorted mate
    Regular Member Batesie's Avatar
    My own little world
    I had a 1.2 corsa c with the same auto box and i had the very same problems plus engine power was cut in half.(not that there was much there to begin with though hey)
    Jan 2006
    Hornchurch
    Quote Originally Posted by CDTi
    had a few of them in the past hope you get it fixed mate
    My own little world
    Lucky i got rid then........
    Although the spanner light thingy is showing on my 2.2 dti sri now as well...
    When will it stop ????
    Is there a vauxhall god ??? i`m thinking not...
    May 2006
    Regular Member Cheeky_B's Avatar
    Irvine, Scotland
    burn it
