Thread: What have I done??
    Jul 2010
    Warrington / Liverpool
    Default What have I done??
    Morning boys and girls,
    It seems I have done something wrong whilst changing my front coil springs last night, thing is I have no idea what...
    I changed the springs from standard to the lowered GSI/SRI springs, which seemed great for about 6-7 miles, then I could hear a horrible rumble from the passenger side when coasting.
    This rumble got progressively worse over a couple of miles and now it is quite loud.
    I'm sure I got everything back on right, except that I snapped one of the three bolts holding the top of the strut under the bonnet, I got the stud out and replaced it with a normal M8 bolt but i thing it may have been a bit longer... could this cause a problem (with the bearing plate being under there).
    I also torqued everything up approximately right (didnt have an angle tightenening guage).
    I think I got the strut-swivel hub bolts back in the right place but they may be very slightly out of position as I struggled getting them back in the marked position on the strut as I marked it with a paint pen, which then ran whith the penatrating fluid.
    Could any of this cause the horrible rumbling (sounds a bit like tyre is totaly flat) or does anybody have any other ideas?
    Sorry for the long post lol, hope its legible...
    Regular Member paul.sessions's Avatar
    leighton buzzard
    i dont think any of that could be making the noise, sounds worrying though did your wheel go back on tight.? and the brake sensor and pipe clipped back in properly not fallen.? i would pull the wheel off and double check droplinks etc all done up tight.
    Jul 2010
    So you don't think I've damaged anything then lol, good news, shall pull the wheel off again once I've had breakfast lol. Cheers boss thanks for the reply
    leighton buzzard
    i took my suspension off about seven times when i was hunting down a knocking noise. its hard to break something, could be wear on another component wheel bearing maybe? obviously when you lower the car you are putting strain on all the other suspension components.etc..
    Jul 2010
    Is there anything i should have replaced? Vx told me they dont bother replacing any of the nuts or bolts they just re-use them, so I did lol...
    Administrator plasma's Avatar
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    as above, reused all the existing nuts/bolts when I do suspension jobs. A bolt which is too long on the strut will come through and rub on the spring. May make a noise when you turn and it rubs, dont think this is the noise your talking about though.
    Check to make sure you havent squashed the disc back plate against the disc because this can make a terrible noise.
    Jul 2010
    Well got the wheel off last night and there was a big lump of **** between the wheel and the hub... re-checked everything was done up nice and tight and cleaned up abit down there and the noise seems to have gone...
    Got a hell of a wheel wobble now though at around 90mph, sure i can live with that though untill i get some new wheels and decide whether i'm going to lower the car...
    Cheers fellas for the replies, top lads
