Thread: Heat deflecter
    s yorks
    Default Heat deflecter
    my heat deflecters come off and making a rattling noise underneath can i put it back on using everyday washers
    cheers
    andy
    s yorks
    Angry
    well tried this 2day and the nuts are the type with the washer attached when i tried to loosen them i used wd40 to get through the rust 1 slight turn of the nut and the bolt sheared off it looks like they use locktite so its off to garage in morning
    Jul 2009
    The Rift, Cardiff
    Mine's the same, makes an awfull noise when going over harsh bumps. Only one of the original bolts is still there holding it on and a couple of screws drilled through.
    s yorks
    did you drill holes into the underneath where the shield bends round the parallel bars the run down the sides....im thinking pop rivets
    WGAF#5
    my old siggy did this ....just pulled em off and didnt worry
    s yorks
    yeah but isnt it to stop the heat from the catalytic
    s yorks
    dez garage ripped it off nd said theyre a waste of space lol...2 min job f.o.c so chucked him couple of quid for a pint
  1. Windscreens - Heat absorbing or heat reflecting?
    By Caveman_nige in forum General Motoring Chat
    Last Post: 4th February 2013, 22:09
  2. heat pad
    By male 2.2 in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2012, 15:09
  3. we have heat at last
    By cockney16v in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 17:53
  4. No heat
    By schmuh in forum Electrical & ICE (including SatNav)
    Last Post: 7th October 2009, 23:36
  5. and then, there was heat !
    By suj786 in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2005, 17:50
