Thread: LED sidelights
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default LED sidelights
    any one managed to get LED sidelights working, ive fitted a resistor but still get the strobing after the lights are turned off.
    ive heard they can be hard wired, but how ?
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    It would be much easier to just buy the mtec 501's if you don't want the strobing.
    Feb 2006
    north east
    Quote Originally Posted by Aikon58 View Post
    ive got them fitted mate , still very blue not pure white, like leds
    they look even more blue with the low beam off
    Regular Member 0uT1aW's Avatar
    Aug 2010
    York
    Even with the resistor you get strobing so Iv read, it only stops bulb warning?
    Hard wired to something like the dash lighs or something. leemarksmith has a thread somewhere i think, link is on his profile
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    This is waht i did... http://www.vectra-c.com/forum/showthread.php?t=112369
    But all you need is a bit of speaker wire and 2 x 501 bulb holders - feed from the dash illumination and jobs done
    Feb 2006
    north east
    Quote Originally Posted by leemarksmith View Post
    thanks mate , (feed from the dash illumination) how would i do this ? ive got the bulb holders , sorry if im being a bit thick
    18 Post(s)
    Mileage : 110k
    Quote Originally Posted by The Gas Man View Post
    Get the power from ANY grey/yellow wire from behind the dash...
    If you remove the rear ashtray you may have some wires in the to take the power feed from, if not the cig lighter bulb is another. Or any from behind the dash practically...
    Feb 2006
    north east
    can any wires be located under the bonnet ? not sure how i can run wires from the dash to the lights
    SCOTLAND
    Is it possible to just make the sidelights be on all the time when the ignition is turned on sort of volvo / DLR style that way they wont strobe when driving.
    18 Post(s)
    Mileage : 110k
    You can run the wires from behind the glove box, through the rubber grommet and it comes out between the wing and battery box...
    As for ignition, just use any black feed... So ignition live from cig lighter or similar but same principle...
    Yellow/grey - comes on with standard light switch.
    Black - will come on with ignition then.
    I finally went with the yellow/grey as i always put lights on anyway and you get the sidelights on with key fob lock/unlock then
  1. None LED sidelights
    By ridgers84 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 02:34
  2. sidelights
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2011, 17:02
  3. led sidelights
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2011, 16:22
  4. what sidelights???
    By damadom in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2009, 02:38
  5. L.E.D sidelights
    By storey_3000 in forum Vectra C / Signum Car Chat
    Last Post: 22nd December 2006, 20:08
