Thread: Snapped two Sealey Brake Wind Back Tools today
    Sep 2010
    Glasgow
    Default Snapped two Sealey Brake Wind Back Tools today
    So - real crappy day! Figured I would get the brakes done - easy enough to do. got the parts and tools out just to be cursing the living daylights out of the wind back tool two hours later!
    I used a Sealey VS0282 18 piece kit which came recommended. Within two attempts to turn anything the handle was bending and ten minutes later the bleeping thing just sheared off where the adapter to the pad sits Aehm, ok, so I may be strong but that strong? Fine, luckily there is another handle in the box, LH mind you, which had the same fate 20 minutes later
    Without using any extensions, levers, breaker bars or the likes I basically managed to reduce this kit to scrap in 30 minutes - Not impressed whatsoever!!!
    Any thoughts?
    Full Member vectraturbocal's Avatar
    Aug 2010
    leeds
    u wasnt turning it the wrong way was you? as some are left hand thread and some are right hand, im just talking motors in general, never done a veccy so im sure someone will correct me if im wrong but it would make sence if it was the wrong way as it would push the piston out making it tight enough to snap it.
    Sep 2010
    Glasgow
    Quote Originally Posted by vectraturbocal View Post
    Turned it clockwise, which would be the correct way AFAIK. Only used the other one out of desperation. I wonder if my caliper is seized But then again, surely that is unheard of with the high quality car we all have
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    get your money back on that kit for a start... it is possible for the caliper to be seized, you need to free the piston up, not had to do this myself but i am sure there are some vids onthe net showing what to do.. 2nd hand calipers are plentiful on the bay, it may be easier to change it if its seized, you can buy refurb kits as well..
    Engine : 1.9 CDTi
    They should turn back quite easy.
    It does sound like the calliper is seized. What are the disc's like?
    Oct 2007
    Shropshire
    Sealey tools are normally pretty good. The windback tools are not meant to be strong because winding back should be easy. If it were not, then something was wrong. I imagine it would be very easy to break the tools if you used much force, extensions or not.
    When I did mine you could probs turn them with finger and thumb...
    durham
    Trim : Leather
    Hi hotrod, I had exactly the same happen I could see the bar was bending so stopped at that point. The callipers were seized and would not retract, I had a rubbing and squealing noise on the rears. Don't bother with these refurb kits get fresh callipers mate.
    durham
    Trim : Leather
    Oh and by the way, nothing wrong with sealey tools IMO
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    You shouldn't have any problem with winding back!, Turn the bar, adjust the nut, Turn the bar adjust the nut, & so on, If its 'very hard' you have a problem!, I Wash my car regularly & the wheels & calipers have there fair share of water so, You may have a problem.
    Regular Member ROCKATANSKY's Avatar
    Apr 2008
    suffolk
    Did you remove the brake fluid cap to allow for the fluid to be pushed back?
  1. Rear brake calipers wind back tool - Herts
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 21:24
  2. Brake piston wind back tool?..
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2010, 15:47
  3. brake calliper wind back tool
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 13:34
  4. Rear Brake Wind Back tool/cube
    By snapsnap in forum Handling & Braking
    Last Post: 4th November 2009, 11:48
  5. What tools will I need to change brake pads
    By rollercoaster63 in forum Suspension, Wheels & Brakes
    Last Post: 24th June 2008, 20:30
vauxhall rear caliper piston trouble winding back site:www.vectra-c.com
