Results 1 to 2 of 2
Thread: Sri 120 cdti - misfire & power loss
    Darlington
    Angry Sri 120 cdti - misfire & power loss
    Hi All
    Im looking for some direction on sorting my vectra sri 120 (without dpf)
    when purchased back in October i had it remapped and everything was fine excellent power and driveabilty.
    recently i had a major power loss and no power below 2500rpm then the turbo came and all the power was there
    so i changed the egr valve and map sensor plus the fuel filter as it was waxed up.
    the car then pulled fine and acclerated fine - straight away i developed a whooshing noise and the car hesitated/juddered on accleration at 1800rpm to 2500 rpm on light/normal acceleration but if you floor it you can drivwe through it - so today i went to see a friend of mine at a vx dealer - we cleaned out the throttle body although there did seem to be a fair amount of oil residue in the turbo pipe upto the throttle body,tried a different maf sensor and boost pressure valve.
    carried out a leak test on the injectors and that check ok but the fault was still there.... so we stripped and clean out my old egr valve and reloaded the software as per the field journal 2149
    although the whooshing noise has diappeared and the car is now running standard without the remap it still seems have a lack of power and slight hesitation....bacsically its flat and seems like its hunting when going onto to boost...
    I have check alot of the pipe work and it all looks ok....Im thinking of removing the plenum chamber so I can view the inlet better ,tomorrow as it seems to be a fuel/air promlem.
    Im thinking it maybe the turbo but how far do you go?
    any help would be great as im now at the end of my teather.
    Many thanks in advance
    Darlington
    Thumbs up
    Prob now sorted - duff egr
    new modified version fitted with new software
    just need the rempa to go back in!!!
  1. 150 CDTi power loss
    By rockafella8587 in forum Engine & Drivetrain
    Last Post: 15th December 2011, 12:48
  2. 1.9 cdti loss of power
    By mark1484 in forum Troubleshooting
    Last Post: 8th July 2011, 08:12
  3. Loss Of Power On 3.0 cdti sri - please help
    By L.Hamilton in forum Engine & Drivetrain
    Last Post: 14th June 2011, 18:00
  4. cdti 120 - loss of power/misfire/surging
    By k12pc in forum Engine & Drivetrain
    Last Post: 22nd January 2011, 21:51
  5. 1.9 CDTI 150 loss of power
    By Nick_206_180 in forum Engine & Drivetrain
    Last Post: 22nd January 2009, 20:57
