Results 1 to 10 of 29
Thread: Condensation problem
    Regular Member bighammerfan's Avatar
    hillingdon
    Default Condensation problem
    Hi. Recently i have had a problem with condensation inside my Vectra. It is on the front and back windows only. I did have a problem a while back with condensation only on the back window and it turned out to be a hole in the exhaust but that has been replaced. Any ideas ?
    Essex
    29 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    have you had you pollen filter changed lately ?? ...also ck that the hole isn,t bunged up with leaves and cr4p ...also use the aircon a bit more aids in the clearing of this .
    hillingdon
    I have not changed it. I have had the car over 2 years. Is this an easy job. Where would the blocked hole be ?
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    chnage pollen filter mate
    Regular Member wallace78's Avatar
    Dec 2010
    belfast
    the drain hole is just below the pollen filter under the scuttle panel !!!!
    Glasgow
    Dry all the water/residue around the drain under the scuttle panel, give it a thorough clean around and in the large rubber drain thingy, then change the pollen filter. When your closing the scuttle panel over make sure all the surfaces are well sealed with no gaps around the edges and bobs yours uncle it should be much better after that.
    hillingdon
    OK nice one thanks. Just out of interest, why does condensation only form on front and back windows and not side ?
    Regular Member no1baggiesfan's Avatar
    Jan 2008
    Newcastle
    Vehicle : 1.8 VVT SRi
    I'd check your passenger footwell mate, if its damp or wet you have had water ingress from pollen filter, I had condensation in my old 2002 vec-c, caused by blocked scuttle drain and water filling up my heater blower from coming in thru pollen filter opening.
    After I cleaned it out I cut the rubber funnel in half, it is a O at the top but it tapers down about 2 inches long, I just cut the bottom half off.
    hillingdon
    thanks for the info mate
    hillingdon
    Sorry to sound thick but where is the pollen filter ? I know nothing about cars !
    Alan
  1. Insignia Condensation
    By bigmac in forum Insignia car chat
    Last Post: 25th January 2013, 18:06
  2. Insignia Condensation
    By neverlandandy in forum Insignia car chat
    Last Post: 25th January 2013, 14:11
  3. Condensation problem
    By BooDaChris in forum Bodywork & Interior
    Last Post: 9th January 2013, 01:36
  4. Condensation problem
    By BooDaChris in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2013, 01:17
  5. Condensation
    By vecest in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2007, 19:05
