Thread: door seal leaking
    glasgow
    Default door seal leaking
    hey i have a 06reg 1.8vvt exclusive and have noticed that the front passenger footwell and the footwell behind the passenger seat are soaking and i mean puddles so put the car into garage as under warrenty for the door seals but have noticed for a while that its still soaking and was wondering if this is a common problem as in winter im having to scraper the ice of the inside of the windscreen more than the out and with the thermostat playing up and not heating the car its starting to get a joke!
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    you need to clean out the drain which is under the scuttle panel fella you will find its probably full of crap then what happens is the scuttle fills up with water and the leaks into the car via the heater motor so you will need to clean out the drain replace the pollon filter and dry out the car just like i had too just this week lol
    http://www.vectra-c.com/forum/showthread.php?t=127127
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    The drain hole rubber is a poor design, its designed to hold rubbish instead of allowing it through.
    16 Post(s)
    Year : 2010
    makes you wonder why the rubber bung is there to start with
  1. Rear door seal
    By conman in forum Bodywork & Interior
    Last Post: 20th February 2013, 19:14
  2. Bendy door seal DONE!!!
    By the-wizard in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2012, 13:34
  3. Door seal leaks
    Last Post: 27th August 2006, 07:32
  4. Split Door Seal
    By sph73 in forum Bodywork & Interior
    Last Post: 21st June 2006, 23:12
