Thread: Steering Rack leaking.Need Help.
    Jun 2009
    Middlesex
    Default Steering Rack leaking.Need Help.
    I have a 2004 2.2 direct with a leaking steering rack.Noticed a while ago and is getting worse and now need to think about getting it sorted.
    Been looking through the forums, and am i right in saying they cannot be fixed like they can on some cars and that they have to be replaced.
    Are they available like on ebay as i have no idea what VX will sting me for parts and labour but you can guess it won't be cheap.Has anyone had one replaced, if so where would you recommend.
    Dobs.
    May 2008
    Tyneside
    Replaced mine last year for MOT, they said you can not replace the seals. Independant garage charged £290 all in (recon rack was £130). Mine's a 1.8 LS, there are three types of rack, this was the cheapest with the pump under the wing. You can get hydraulic oil additives that claim to stop leaks but not tried these.
    Jun 2009
    Middlesex
    How can i find what type of steering rack is fitted?The car is a (04) 2.2 direct.What are the differences?Can i tell by looking or will VX be able to tell me by chassis no.
    Thanks Dobs.
    May 2008
    Tyneside
    Vx will telll you part number from reg no. The early vectras like mine has a seperate power steering pump under drivers side wing. Later vectras have the steering pump on the rack and hence more expensive. I was informed there is a steering rack with and without the steering angle sensor, although I imagine all C's need this. HTH
  1. Leaking steering rack pipe
    By simon987 in forum Engine & Drivetrain
    Last Post: 27th October 2012, 10:16
  2. Leaking steering rack
    By dittohead in forum Vectra C / Signum Troubleshooting
    Last Post: 21st March 2011, 18:33
  3. Power steering rack leaking
    By fuzzbomUK in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2010, 15:13
  4. Steering rack leaking
    By aos in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2008, 00:01
  5. Leaking steering rack
    By BobbyV in forum Engine & Drivetrain
    Last Post: 3rd February 2008, 17:32
can i use leak stop in a vectra c steering
leaking streering rack vauxhall vectra c
