Results 1 to 10 of 13
Thread: Squealing Brakes
    Regular Member richardg3.2's Avatar
    Hull
    Default Squealing Brakes
    I remember someone posting a little while back (can't find the thread) about having a problem with brakes squealing especially when turning a corner with no brakes applied. Well mine had started doing this, would squeal when I turned left, applying the brakes did reduce or eliminate this. On the previous thread it mentioned that it may well be caused by the lip that builds up on discs with some wear on them. Figuring this may be the problem and as Vaux were doing discs and pads for £45 through the trade club I decided to just replace them. Fitted them last night, plenty of copper grease on the backs of the pads etc. Got in the car to go to Asda, fine for about 2 miles then went round a left hander and it started again. Over the next 2 miles it got progressively worse until the squeal was constant and even applying the brakes didn't stop it. Going round a right hand bend it did reduce considerably.
    Got home tonight and took the wheels off to have a look and found the problem. Did the brakes in poor light last night so didn't notice but there is a thinnish metal shield/plate that sits between the bottom ball joint and the disc which I assume is designed to remove debris from the disc before it gets round to the caliper. The gap between the ball joint and disc is pretty small anyway and basically muck from the road has got between the ball joint and the shield and forced it closer to the disc until it makes contact. This explains the variation in squealing depending on steering lock because the shield moves around the ball joint as you turn the wheel.
    Simply cleared the bit of muck out and pulled the shield off the disc with my fingers (easy to bend) and no squealing Obviously changing the discs made the problem worse as the new discs are that bit thicker so made more contact with the shield. Hope this helps out anybody suffering the same problem.
    Regular Member Ian's Avatar
    York
    Nice one Rich, good advice there bud.
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    Hmmmm....me thinks this is my problem!
    CONNAH'S QUAY
    thanks for that I took mine off about 4 times after replacing front and back pads and disc's in the summer gave up after applying copper grease to everything I thought was causing it.
    Good call, I have also experienced something similar with a small stone trapped around the disk, sounds like the thing as about to fall apart ...
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Post #2 shows where the shield is http://www.vectra-c.com/forum/showthread.php?t=47958
    It's not there to scrape crud off the disc but acts as a small heat shield to prevent disc heat transferring to the bottom ball joint bellows.
    Regular Member lewcdti's Avatar
    Oct 2010
    South Wales
    Thank god for this site!
    I had squealing when turning and was getting proper worried. Thinking I was gonna have to get new tyres, disks, pads, shocks, etc, etc, etc......
    Then I searched 'Squealing when turning' on here and found this thread. Literally a 2-minute fix. If you know whereabouts to put your hand, you dont even have to take the front wheels off, just turn full lock so you can get your hand in behind..
    Thanks!!!!!!
    Regular Member Nato's Avatar
    Risca, South Wales
    This has also reminded me why I paid to renew my subscription to the site this year! 5 minute job each side (including removing and replacing the wheel), and bye bye squeal!
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Thanks for the heads up, something I need to look at.
    Do you have to take the wheel off or can you get at it with it on? (my locking nuts won't come off on the front)
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Quote Originally Posted by richardg3.2 View Post
    can anyone get this trade price club thingy??
  1. squealing brakes
    By dcm23251981 in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2012, 01:25
  2. Brakes squealing
    By davidlewis24 in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2011, 20:33
  3. Squealing brakes
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 18th December 2009, 21:27
  4. squealing brakes
    By HooDLuM_X in forum Handling & Braking
    Last Post: 17th July 2008, 11:24
  5. Squealing brakes
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 12th July 2008, 19:19
