Results 1 to 10 of 13
Thread: Hybrid Turbo spec for 1.9CDTI
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Default Hybrid Turbo spec for 1.9CDTI
    Well I have the tubro back after it was repaired and I will be fitting it this week, once I get a brand new oil feed pipe for the turbo.
    The compressor is up from 49mm to a 52mm exducer with a 39mm inducer. The shaft and bearing is also uprated, so I look forward to trying again!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Hi mate here did you get it done and how much as I have been planning to do the same
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    They have made it but the first fitting didn't go well, some particulate contamination of un known source or type... Possibly in my oil they tell me...
    Anyway, rebuilt at no cost, so I will try again after Tuesday when I get the new pipe.
    If you are interested, I think they want 650 quid for an exchange unit. I got one off ebay for 110 quid and used that for the upgrade. Let Turbo Technics know if you are interested, as it took me over three years to get them to make one!
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Let us know how it goes and feels and if there is any increase in boost pressure too. Also a rolling road should be handy too les us know some figures
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    I hope this one holds together mate.. looking forward to your feedback..
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Well it was holding solid at 1.7bar before it died last time and that was before I turned the boost up. I will be doing a rolling road in two weeks in Leeds with 29 other diesel, so I hope to have everything up and running well by then.
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    do you have a manual boost controller or something?
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I have a CRD-T which links to the fuel and boost
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    As they haven't established the 'source' of the contamination what happens if it does the same? Seems a lot of fettling at your end to get it to work out.
    Gazza4
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I have 10 ltr of oil, new feed pipe, new oil filter and a new turbo. I will ditch the oil while hit, refill and run until hot again then ditch that lot, then I will refill and change the oil filter. New, remove old turbo, fit new feed pipe, stick it together and hope the problem does not reoccur... Nothing much more I can do.
  1. Hybrid Turbo
    By toughmat in forum Diesel Engine related
    Last Post: 1st May 2013, 17:16
  2. Hybrid turbo here we come!
    By Telly Addict in forum Vectra C / Signum Car Chat
    Last Post: 3rd September 2012, 21:52
  3. Hybrid turbo
    By R2XPT in forum Diesel Engine related
    Last Post: 28th January 2012, 21:05
  4. Hybrid Turbo for 1.9CDTI 150
    By GazVXLINE170 in forum Diesel Engine related
    Last Post: 6th April 2011, 23:57
  5. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
