Thread: engine nightmare
    fife
    Default engine nightmare
    Hi All, hope you can help as i,m new here
    Before i ask i have to let you know why i am asking,
    I purchased a vectra c believing it to be a 1.9 cdti sri (150) with a knackered engine that had been stripped apart and left with just the bottom end in it and the rest chucked in a box in the boot (first mistake)
    I located another z19dth engine paid for it today and picked it up i then got the car on a ramp and proceeded to remove what was left,I then noticed a couple of differences and then pulled the box of bits out the boot to find a 8v cyl head and a z19dt sticker on the timing belt cover
    so my question is will the 16v engine run in this car i know there,s a swirl valve motor in the 16v but this should not operate as my ecu won't be looking for it. I have checked wiring diagrams for both engine types and the both look the same with the same components wired to the same pin location in the ecu so can't see why it shouldn't work BUT hope you peeps may know better
    Thanks for reading i know its a bit of a story but this is my dilema
    Full Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    33 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 256,000
    Sorry to hear about your problem. I don't know the answer. Have a free bump anyway, though.
    Good luck getting the car sorted.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Regular Member mozzer99's Avatar
    bristol
    In the absence of a more knowledgeable reply - - - I would expect at least the ECU mapping to be quite different. As changing the ECU is difficult (security coding) it may be that having it re-mapped at a tuner to 150hp spec is the answer?
    To add to your problems as the car you have is registered as a 120hp, insurance will class it as modified (to 150bhp) and load the policy. Seems you can't just declare it as 150bhp as they now use the original registration details from DVLA.
    Good luck!
    fife
    thanks for the reply's but just going to put it in and see what happens Fingers crossed lol
    fife
    decided to get the right engine as i checked all, and wiring is different so if anyone knows where i can find a z19dt please!!!!!!!!!
    Engine : 1.9 CDTi
    fife
    Quote Originally Posted by lee gsi View Post
    Thanks mate going to e,mail see what comes back
    Dec 2010
    kent
    Had the same problem ,bought a signum unseen with engine in bits ,told it was a 150,sourced an engine and bought the car on arrival its a 120,seller didnt want to know ,******* even quoted his solicitor saying it was down to me to confirm description !so had to find a 120,all fitted but now have a problem with tank pump not running.
    Dec 2010
    kent
    Be interested to know if yours runs without coding pump and injectors to ecu ,opinions vary as to wether you need to do this.
  1. Been a nightmare.
    By JM53 BEL in forum Engine & Drivetrain
    Last Post: 31st January 2013, 00:15
  2. Engine nightmare with a Vectra 1.9CDTi 150 on a 05 plate
    By sailingthewild in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:06
  3. Could my nightmare nearly be over.
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2010, 20:45
  4. Nightmare day!
    Last Post: 5th February 2010, 12:18
  5. What A Nightmare............
    By payney in forum General Chat
    Last Post: 9th September 2005, 09:55
