Thread: Wiper linkage broke - ****ing scuttle panel wont budge
    Regular Member eaglepva's Avatar
    Up North
    Default Wiper linkage broke - ****ing scuttle panel wont budge
    Been trying for most of the day to try and get the scuttle panel off so i can replace the broken wiper linkage with the replacment rods of ebay.
    I cannot get the ****** scuttle panel off it wont move. ant tips or hints?????
    Also ive tried just pushing the replacment rods on the sockets but it will not go on the old ones push straight on but the new ones will not push on no matter what
    Jul 2009
    The Rift, Cardiff
    I found the best way to get it off is to very firmly pull up in the middle. There is a thin channel along the bottom of the screen that the scuttle tray clips into. It helps if you can get you fingers between the screen and the lip of the tray that over laps it to give a little wiggle while pulling. It needs to flex in the middle to help get the edges out from behind the bonnet hinges and under the wing.
    Its probably best to try and disconnect the washer hose before removing the tray to prevent damage. And while its off give the drains a clean out, one by the pollen filter and one on the drivers side by the wing.
    Up North
    tried allsorts today m8. Even rang the parts department at vauxhall to price a new scuttle panel if it was cheap enough i was just going to snap the old one off but at £57+vat for a new one i think i will have to keep trying.
    Sep 2010
    north east uk
    I changed my wiper rods (from ebay) just before xmas.
    Couldnt get the wiper arms & scuttle off, so decided to have a go at changing them leaving the scuttle panel in place. I was about to give up trying to get the new rods over the balls, as the new rods are a good tight fit.
    Then i remembered i had some "plumbers" type of pliers in the boot, so i used them to squeeze the new rods over the balls. Worked a treat & had them on in less than 5 mins.
    EDIT, heres a pic of the type of pliers i mean.....note the long handles which give a good ammount of pressure when squeezing the new rods onto the balls.
    Up North
    I couldnt get the wipers off either m8 so bought a wiper removal tool £10 that done it straight away. Will give the abvove a go tomorow and hopefully it will work.
    Sep 2010
    north east uk
    Hope it works for you mate. Its a bit fiddly but do-able, you will get a few cuts & scratches on your hands though
    I made sure i fitted the most awkard ones to get at first, which are the lower ones, IIRC,
    Up North
    Finaly got it all done today. Got a pair of them pliers like above took all of 5 mins just by putting my hand under the scuttle panel. Now ive got perfect parked wipers.
    Cheers for the tips lads.
    Sep 2010
    north east uk
    Well done mate.
  1. oil filter wont budge!
    By djlee in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 16:09
  2. passenger seat jammed right back on runners and wont budge!
    By richiem in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2011, 22:28
  3. odd staining on front headlight lens that wont budge?
    Last Post: 11th April 2011, 20:17
  4. Replies: 11
    Last Post: 10th July 2008, 22:52
  5. Help..indicators wont budge!
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2008, 20:12
