Thread: these boost/vaccum pipes ...what do they do?
    Jan 2010
    worcs
    Default these boost/vaccum pipes ...what do they do?
    ive just been having a good luck round the engine bay as i can smell fuel when the engine is running ?
    i come across a pipe that looks very perished on the front of the engine just in front of the oil filler cap.
    the pipe in question comes off a unit which i think says "vaccum " on it and goes to a metal pipe.
    as i said this pipe is very worn/persihed.
    what is its function and would it make my engine response a bit sluggish?
    also any ideas why i can smell fuel when the engine is running? i cant see any leaks but i can definatley smell it towards the back left hand corner of the engine at the top?
    car is a cdti 150 sri.
    cheers
    steve
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    just a little check, make sure your injectors seals are ok and not chuffing take the cover off and listen for a tuffing noise and look at the injectors and make sure there is no bubbling and if there ok check all the breather pipes etc as for the vacuum pipe i dont think it could cause the smell but it would cause there to be a drop in performance
    north east
    The pipes control the wastegate and boost as well as braking.
    what you need is som 4mm internal diamiter silicone pipe off ebay, about £3 a meter you only need 1 meter on the 150.
    Jan 2010
    worcs
    just read the thread on this and have ordered the relevant piping from ebay!!
  1. Boost/Vaccum pipes
    By garetmcc79 in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2012, 12:25
  2. Vac And Boost Pipes
    By zonerc in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd June 2011, 15:54
  3. Boost pipes? CDTI120
    By CDTI120SXI in forum Vectra C / Signum Troubleshooting
    Last Post: 16th May 2011, 08:52
  4. boost sensor pipes
    By nufckev in forum Engine & Drivetrain
    Last Post: 6th October 2008, 22:03
