Thread: the check safeguard message
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    confused the check safeguard message
    a while back i fitted a rear interior light at the same time i managed to break part of the roof loom since then ive had the message check safeguard, bought a new loom today as i asumed this is the problem but today ive come across something about the heated rear window having something to do with alarm is this true??? i know i have bits ov the heated window that are broken as i can see bits that stay misty in the mornings.
    Jul 2010
    doncaster
    found some conductive paint on ebay so im going to fix it anyway
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Check Safeguard normally means there is an issue with the alarm, as the ultrasonics run off of the roof loom chances are that's whats causing it.
    I haven't heard of the rear window demister being part of the alarm. You got access to a code reader/ tech2 etc? That will help you find the problem.
    Jan 2010
    northamptonshire
    hi i had this problem before xmas went into vauxhall dealer the connection to the rear screen had burnt out which put the message up on the dash had it repaired all ok
    Jul 2010
    doncaster
    turns out it was the damaged part of the roof loom, fitted another loom today and all is good put light up sun visors and map lights in at the same time
  1. check safeguard message fault, and computer screen staying on, what can it be?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2012, 17:44
  2. Help safeguard message beig displayed
    By chuckleuk in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2011, 11:29
  3. Safeguard message and no alarm
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2011, 21:44
  4. "Check Safeguard" Message
    By Loz2286 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th February 2011, 16:47
  5. Safeguard Message
    By TJC77 in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2011, 21:28
safeguard message on vectra
