Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: just got my first Vectra..! Do these cars have a glowplug Light?
    Lancs
    Default just got my first Vectra..! Do these cars have a glowplug Light?
    Hi there, 1st post...!
    Just got a vectra last night a W reg 2000 2.0l DTi Eco-tec engine.
    Took a while of turning the starter motor over this morning to start the car. The battery seems good as the starter was turning nice and fast.
    There doesnt seem to be any glowplug light coming on on the dash when turn the key, it was -2' this morning so would have expected to see a glowplug light on.
    Left it to cool while at work just been out at luch to test it and it struggles a bit to start up again, once it starts its fine.
    Thought it might need new plugs but first need to know if a light should come on....?
    Thanks.
    Charlie.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    yes it sits at the bottom of the dash, between the rev counter and speedo.
    Gazza4
    Lancs
    cheers gaz
    is it orange with a coil on like most other derv cars with a light.....? I defo didnt see one come on if it is...!
    So what does this mean if no glow plug light, is the light part of the actual plug circuit or just on a timer as a guide....?
    So many questions for my first thread, soz...!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    It is orange and a coil symbol. It's part of the circuit and controlled via a relay. Only if the temperature drops below 5C inside the engine, the engine will need pre heated. This is ultimately controlled by the ECU.
    Gazza4
    Lancs
    ok thanks, because some cars the dash light is just a light on a timer and no-way connected to the plug circuit.
    So... the car would have defo been below 5' this morning and no plug light came on so would that indicate a faulty relay or temp sensor...?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by chaz View Post
    Possibly or the light on the dash has blown.
    Gazza4
    Lancs
    thanks.
    I'll check if the plugs are getting correct voltage first and take it form there
    Regular Member Sparky28's Avatar
    Lincs
    If you have a fault there will be a eml light up i only have 1 glow plug not working and i have a eml light up
    Lancs
    cheers sparky.
    is the eml light up all the time....?
    Just wired how the car is not starting well and there is no glowplug light coming on.
    next cold morning i'll check the voltage going to plugs to be sure they are getting some.
    if they are then i gues it could be leak off pipes maybe or do these engines have a hand fuel priming bulb anywhere....?
    thanks.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Sparky28 View Post
    What he said. The heater light will come one even if the glow plugs don't work. Sorry I realise we have had our 'wires crossed' there.
    Gazza4
  1. no glowplug light, why???
    By frasedeb in forum Engine & Drivetrain
    Last Post: 22nd January 2013, 23:05
  2. Flashing glowplug light
    By Tankman10 in forum Engine & Drivetrain
    Last Post: 8th December 2012, 11:05
  3. glowplug light
    By clyde in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2011, 00:39
  4. glowplug light
    Last Post: 13th October 2009, 13:54
  5. glowplug light
    By bob4 in forum Vectra C / Signum Troubleshooting
    Last Post: 12th October 2009, 20:52
