Results 1 to 10 of 15
Thread: Newbie looking for advice ...
    fife
    Angry Newbie looking for advice ...
    I have a 1.9cdti sri on a 05 plate and have had it for just over a year. It has had intermittent problems since i got it but now I have really had enough. I have been told that it needs a new swirl flap manifold, intake manifold, EGR valve and at the same time the timing belt should be replaced aswell all at a total cost of £1302.00 plus £108.00 for the diagnostic test.
    When i phoned the garage for more detail the technician said it was a common problem on z19 dth ... does this not mean then that it is a design fault ????
    They explained about the sticky egr valves etc but then said that on the swirl flap manifold one of the rods have broken causing damage to the other parts and so guess what its not covered by the warranty because they are damaged and not faulty ... another get out clause!!!! thus leaving me with the hugh expense as detailed above.
    Can anyone help me with any ideas ... Many thanks
    Sep 2010
    Vauxhall don't accept 'design faults' - I was advised that modified parts for replacement of clearly obvious design faults were 'Vauxhall's commitment to ongoing improvements'!!
    Is this a VX quote?
    fife
    Hi this is a quote from a vauxhall dealership that only sells the make ...
    fife
    I was also told that it happens more frequently in a car that does short journeys rather than long journeys .... with the price of diesel nowadays who can afford to do small journeys but either way i thought a car was designed to be driven regardless
    Jan 2010
    wirral
    Seems a bit steep, but then again, I would not expect anything less from a dealer.
    Just to give you an idea, I had my inlet manifold and actuator done late last year, the bill was £599. I also had cam belt done (full kit) paid £250 for that and the EGR valve can be bought for around £100 and fitted quite easily yourself. So you can get the work done for a good bit less if you shop around.
    I'm not sure the cam belt would have to be changed at the same time but if its near the end of its life span, it would not be a bad idea to have it changed.
    fife
    Hi i do not know if it is ... they just said its a good idea to change the timing belt as well ...
    fife
    is this a common problem that once recified all is ok or will it go again as they have said due to short journeys ...
    Jan 2010
    wirral
    Think the cam belt is due at 100k, I changed mine at 80k when I bought the car just to be safe. I don't think that short journeys will knacker the inlet manifold any quicker than long trips. There was a problem with them on earlier models and vx re-designed the newer ones to eliminate the problem....i think
    fife
    i'm sure it hasn't reached 80.000 on the clock and that was some rubbish i was given by one of the technicians at the place that has the car
    Sep 2009
    middlesbrough
    Hi mate iv just picked mine up from having the above work done, mine was on 98k so I decided to have the cambelt done at the same time as it's due at 100k, if I was in your position I would also have a new cambelt kit and waterpump done while it's in bits, then you need a new modified inlet manifold and a gasket, I ordered mine from autovaux and it came to £308.00 in delivery, i then just rang a load of local garages who all quoted about £200.00 so I went with a fiat specialist as it's mostly a fiat engine. I didnt replace the actuator for the swirl valves because mine was working, you can check this yourself bu pulling the engine cover off and having a look down the back of the manifold, you will see a metal bar, this is probably just lying there, you will then see 4 black holes which the bar should be connected to, count the 3rd hole from the left side standing at the front of the car then get somebody to rev the car, if this 3rd hole moves then your actuator is fine and dosnt need replacing, my car had lost alot of power intermittently so I booked it in for the work but before it went in I removed the egr valve which is very easy to do and cleaned it out, the plunger in mine was seized so I freed it off and refitted the egr, the car ran fine so I would suggest doing this first as there are people on this forum who have had the bar fall of the manifold and there car has ran fine for 30000 miles and counting so I would try this first, only reason I went ahead with all the above work was because I'd ordered the bits and booked it in at the garage before I cleaned the egr, my cambelt was also due, all in it cost me £500.00 and that's including a cambelt and waterpump change which pretty much any car would need so I don't think it's to bad as some people will charge £300 just for a cambelt change, sorry for the long post but hopefully it will help you a bit
  1. Newbie needs advice
    By dazmufc in forum West Midlands
    Last Post: 2nd September 2011, 13:45
  2. Newbie here after some advice
    By holsts in forum Introduce yourself.
    Last Post: 25th July 2010, 12:10
  3. Newbie looking for advice?
    By Rhbjones in forum Introduce yourself.
    Last Post: 7th July 2010, 00:54
  4. Advice for a Newbie please....
    By pami in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 13:02
  5. newbie here.. also advice please :)
    By raggit in forum Introduce yourself.
    Last Post: 18th March 2010, 12:11
