Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: MAF Problem? 2002 2.0dti vectra c
    Dec 2010
    wigan
    Question MAF Problem? 2002 2.0dti vectra c
    I removed my maf yesterday and i noticed there was no resistor on the housing just some terminals where it should go. I was just wondering if there should be one here? I have seen a replacement one on this website http://www.expressauto24.com/epages/...cts/0281002479
    This shows there to be one but im not sure if this is a universal picture.
    Your help would be much appreciated!!!
    Dec 2010
    wigan
    Can anyone help please? I'm looking at this because I am getting poor fuel consumption and I am working my way through the possibilities. I know the IAT and MAF are both in this unit. I'm just thinking that the IAT is working but the MAF isn't because the resistor is missing???
    Dec 2010
    wigan
    Unhappy
    Anyone?
    Admin plasma's Avatar
    On the Forum
    225 Post(s)
    Engine : 150
    Mileage : 74000
    I'll see if i can check mine at some point today, but dont recall seeing a resistor on the housing.. If the MAF wasnt working correctly it would be running like a pig.
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Dec 2010
    wigan
    Quote Originally Posted by plasma View Post
    Thanks for your help plasma!
    I unpluged the maf sensor yesterday and started the car without it in. It started fine, sounded fine but wouldnt rev past 3 thou revs. I didnt try to drive it though. I would much appreciate it if you could have a look for me! All i can see when i remove the sensor from the housing is just two connection points, As shown on the website pic in first post, but obviously without the resistor. when I type the part number in google I find its only fitted in these cars
    SIGNUM2.0 DTI100 05/03-09/05SIGNUM
    2.0 DTI100 05/03-09/05SIGNUM2.2 DTI125 05/03-09/05SIGNUM2.2 DTI125 05/03-09/05VECTRA C2.0 DTI 16V101 04/02-09/05VECTRA Mk II1.9 CDTI120 04/04-VECTRA C2.2 DTI 16V125 04/02-09/05VECTRA Mk II1.9 CDTI100 10/05-VECTRA C Estate2.0 DTI100 10/03-09/05VECTRA Mk II1.9 CDTI 16V150 04/04-VECTRA C Estate2.2 DTI125 10/03-09/05VECTRA Mk II2.0 DTI 16V101 04/02-09/05VECTRA C GTS2.0 DTI 16V101 08/02-09/05VECTRA Mk II2.2 DTI 16V125 04/02-09/05VECTRA C GTS2.2 DTI 16V125 08/02-09/05VECTRA Mk II Estate1.9 CDTI120 04/04-VECTRA Mk II Estate1.9 CDTI100 10/05-VECTRA Mk II Estate1.9 CDTI 16V150 04/04-VECTRA Mk II Estate2.0 DTI 16V101 10/03-09/05VECTRA Mk II Estate2.2 DTI 16V125 10/03-09/05VECTRA Mk II GTS1.9 CDTI120 04/04-VECTRA Mk II GTS1.9 CDTI100 08/02-09/05VECTRA Mk II GTS1.9 CDTI 16V150 04/04-VECTRA Mk II GTS2.0 DTI 16V101 08/02-09/05VECTRA Mk II GTS2.2 DTI 16V125 08/02-09/05
    Thanks again!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    here you go m8 bosch part no 0281 002 479
    vx part no 2443 7503
    The pics come from my maf removed when i purchased a new one thinking this one was faulty but it was not so now its a spare
    and still loving it
    Dec 2010
    wigan
    Thanks for the pics bobssignum! This is the same part number as mine but I still can't see the part where the resistor goes on the pics. It needs the screws removing and pulling out the sensor from the casing and the resistor is situated on the outside of that. I will try and remove mine later and post a picture of mine and a picture of the replacement one from the website above. I also contacted Vauxhall to ask and they were as useful as a chocolate fire guard!
    Thanks again Hugheso
    Dec 2010
    wigan
    The first pic is of my MAF sensor and as you can see there is no resistor there you can just see the terminals. In the second pic you see the same unit obviously removed from its housing but with a resistor there. And my question should I have one? I hope not as I will be wondering where its gone!
    But if it should at least I know to get a new one!
    Hope someone can clarify this for me!
    Thanks!
    Nottinghamshire
    I think that's the actual air flow sensor, not a resistor - although they do look similar. It looks like it's broken off somehow.
    Google 'MAF sensor' - there's loads of information and pictures about them.
    Dec 2010
    wigan
    Quote Originally Posted by James24 View Post
    Thanks for your input, I have looked at google and there is nothing definitive telling me. Could someone please take off theirs and let me know. It would be much appreciated!
    Thanks again
  1. Abs and Traction Control warning lights on in 2002 Vectra C 2.0dti
    By Dori_Rory in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2013, 18:20
  2. 2002 vectra c fuel pump problem
    By daz28 in forum Engine & Drivetrain
    Last Post: 10th April 2011, 21:07
  3. vectra c 2.0dti cold start problem
    By Ade-c in forum Engine & Drivetrain
    Last Post: 12th February 2011, 14:35
  4. vectra c 2.0dti glow plug problem
    By barrymanalow87 in forum Engine & Drivetrain
    Last Post: 17th April 2009, 19:04
fitted new brake pad sensor on vectra and now traction control light comes on
vectra c 2.0 dti maf sensor resistor
2004 vectra c 2.0 dti maf problems
vauxhall vectra 2.0 dti 04 brake wear sensor light showing
