Results 1 to 10 of 14
Thread: How to fit an alarm on a Vectra C 2004 2.0 Diesel?
    Dec 2010
    Timisoara
    Question How to fit an alarm on a Vectra C 2004 2.0 Diesel?
    Hi,
    I have purchase today an original car alarm for my Opel Vectra C from 2004 , 2.0 TDI . I'm from Romania so in my country Opel is equal to Vauxhall.
    The alarm come of from an identical car so it's Second Hand.
    The problem is that it has a couple of cable cuts that I don't know what are there for.
    I will post pictures of the alarm and all the cables if there is somebody here who is willing to help me or has done similar jobs like this.
    I also will like if somebody here can post an schematic of the alarm wiring.
    Best Regards,
    Cornel
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    I know that the user Sulten have retrofitted alarm to his car.
    and i know you would need a new BCM
    Dec 2010
    Timisoara
    Hi,
    I have the BCM from the car that had the original alarm. I have all the things that I need. The owner of the car alarm provided me everything including a reset code in case I need to use it. To bad he didn't had any schematic. He basic told me to solder the wires that are cut to the one that math with your car. But I don't know even where to mount the car siren or where is the BCM location even.
    Any help is welcome. Picture will be best for me.
    Best regards,
    Cornel
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    The siren goes behind the REC (remove it and it sits behind there)
    BCM in on the backside of the fusebox (thats there where you open the drivers door), you have to remove headlight switch and the bits below the steering wheel to get access to there..
    Dec 2010
    Timisoara
    Hi Kenp,
    I'm a nub when coming to car components name. So please explain like you explain to a monkey.
    First I attach pictures of the alarm whirring. Maybe you could explain what dose every cable do and where should they be mounted.
    Also before I start to mount it please tell me if I have indeed everything I need. I trusted the last owner of the car alarm but maybe he missed something.
    Here I have pictures of what I have:
    Car Siren
    Car BCM
    A click. I assume this will be the click to check if the bonnet is open so the alarm is not activated while the bonnet is open
    Some sensors . Where should they be mounted?
    Something that is written laser on it. Where should it be mounted?
    Interior alarm light
    Interior car alarm button
    Here are some pictures of the car pc. Maybe you could tell me where the Interior car alarm button should be placed
    Only the buttons from the top on both sides look like they have some connections. What are the connection for in case there not for the alarm button and how can I make the connection for the alarm button.
    Here are some pictures of the car engine. Maybe you can draw on the picture the location where the siren and the hood click should be mounted
    Best regards and thanks for all the help so far,
    Cornel
    Dec 2010
    Timisoara
    I forgot to add one picture with the wiring.
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    try Sulten (just make him a pm to this thread)
    But i can see that the alarm you have got is not the same as original.. atleast not completly..
    Dec 2010
    Timisoara
    Hi kenp,
    I jest sent a PM to Sulten.
    Can you tell me what is missing? And also can you show me some picture on how the alarm should look?
    Best regards,
    Cornel
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    well maby your alarm sensors are from one of this, but this is how it looks, when all ready to put in.
    http://cgi.ebay.co.uk/Vauxhall-Signu...item3caeb71b71
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    13 Post(s)
    Vehicle : Opel Vectra C
    Trim : Cosmo OPC Line
    Hi
    Read your PM, but I don't think I can help you with this. This is not a factory fitted alarm you have.
    The BCM, switch and bonnet switch is ok. It may be a after marked kit from dealers.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
  1. problems with vectra 2004 diesel 120bhp
    By DavyB in forum Vectra C / Signum Troubleshooting
    Last Post: 29th February 2012, 11:03
  2. Vectra Alarm
    By davidallanmcdonald in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2011, 11:41
  3. 2004 vectra 3.0 v6 diesel automatic gear box
    By vectra 3.0v6 sri in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 23:05
  4. 2004 DTi Alarm Problems - Goes Off All The Time
    By vectraliam in forum Engine & Drivetrain
    Last Post: 9th February 2010, 18:25
  5. What alarm on 2004 1.9CDTi SXI 150?
    By VXR CDTi in forum General Chat
    Last Post: 10th February 2008, 00:15
vauxhall vectra c 3.0 v6 alarm sirren
