Thread: No power at all from my Vectra 150
    Jun 2009
    Belfast
    Default No power at all from my Vectra 150
    I need some major help.
    I have been looking through the threads on the forum about poor performance of the 150 vectra's. I too have suffered with poor performance with no pulling power under 2200 rpm. I have carried out the following advice:
    Changed the vacuum pipes at the front of the car
    Cleaned the EGR
    Replaced the MAF
    The last thing that I did yesterday was change the MAF. The car ran fine for a couple of miles to which I thought Horaay but then she just died again.
    I have had it plugged in and the computer syas nothing is wrong. Could there be a fault code lurking in the back ground somewhere that I cannot see, so if I disconnect the battery and reconnect again could this clear the fault?
    I am at the end of my budget and I cannot afford to change the car.
    PLEASE please help
    Sep 2010
    staffs
    Have alook if u have a dpf in the exhaust i had the same problem until it stopped completely took it off and its a lot better. still abit sluggish under 2000 rpm but im waiting for it to be remapped the wkend, also clean the boost sensor hope this helps.
    north east
    Have a look in the how to section for throttle repair ;-)
    Jun 2009
    Belfast
    Problem sorted. Turns out the MAF that I bought was faulty once this was replaced the cars runs a smooth as silk.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Take the engine vanity cover off - have a look down at the inlet manifol behind the fuel rail, there will be a zig/zag shaped bar - known as the swirl control rod, since you don;t have a fault light I wouldn't be surprised if the bar is off. Common fault
    If this isn't the problem the Throttle body may be to blame - another common fault in these. There may be cracked solder joints on the throttle control PCB causing open circuit, making the throttle control unit think the engine has been shut down when it hasn't. Worst case - the engine will shut off otherwise power may be seriously reduced.
    Overall sounds like the the manifold and swirl flaps to me.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
  1. vectra no power
    By rioni in forum Engine & Drivetrain
    Last Post: 10th October 2012, 14:56
  2. vectra shuddering and no power
    By morrisseyno1 in forum Troubleshooting
    Last Post: 13th August 2011, 20:24
  3. Vectra power loss
    By jan63 in forum Troubleshooting
    Last Post: 5th March 2011, 19:48
  4. Vectra 1.8i VVT Power Steering HELP!!
    By fluffy25 in forum Troubleshooting
    Last Post: 7th February 2011, 20:49
  5. How do you get more power out of a vectra cdti 120?
    By Pdvectrasri in forum Diesel Engine related
    Last Post: 11th April 2010, 20:01
