Thread: ICE help
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Default ICE help
    hi i brought a Power/Ground Distribution block from the bay item number 170592890708 (sorry cant do links) i was hoping that i can use it for power not for ground does anyone know if i can, the same company sell one the says just ground but the part number is the same.
    Nottm
    Toucan use the item that you have purchased however for a power diatribution block I'd say something that is fused would be better try searching STINGER SPD8124 in eBay this would be better as each power cable has it own fuses therefore you will be less likely to blow the entire system. You would still need a fuse next to the battery aswell.
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    Thanks for the reply Ben, as for the fuse's i will have two digital fused fuse's in the battery comparment running to the distriubtion block then each 4awg output will be fuse's at the amp end, this should be ok yes ?
    Nottm
    Yes that will work the same to be honest you only need a decent glass one under the bonnet then just 20/30 amp spade fuses in line after the distributor block.
