Results 1 to 3 of 3
Thread: Engine Cuts Out at low speed
    Essex
    Default Engine Cuts Out at low speed
    This has recently occurred. If I get stuck in stationary/very slow moving traffic for around 15 mins the EML comes on. Soon after the car will cut out and it wont start until about a minute has gone. It will then cut out moments later if the traffic is still slow. Once I get back to normal speed or park the car up for a while the EML goes off and the car is fine. Tried to download fault codes but its saying there are none, does the fault codes need downloading when the EML is on? Any idea what this could be?
    Regular Member slipperysam1984's Avatar
    Apr 2009
    Bournemouth
    Hi,
    it sound like air or fuel starvation to me.
    when was it last serviced?
    check your air filter for blockage.
    Essex
    Thanks. Thinking about it Ive had some creamy sludge build up in one of the pipes that comes off the engine that could be restricting air flow I will clean this out to see what happens. Thanks for your reply.
  1. 2.2DTI engine cuts out
    By ruthstatham in forum Engine & Drivetrain
    Last Post: 18th June 2011, 22:55
  2. Engine Cuts Out
    By bulletproofpanda in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
  3. Engine cuts out
    By Lloydy in forum Engine & Drivetrain
    Last Post: 26th May 2010, 12:52
  4. engine cuts out
    By thedhj in forum Engine & Drivetrain
    Last Post: 7th February 2010, 14:07
  5. Engine cuts out
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2009, 09:22
