Thread: ma father in laws sick vec - please help guys
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Default ma father in laws sick vec - please help guys
    hi, got my father in law in tonight. hes got a 52 1.8 vec sxi. now hes been have running problems with it. mainly running like a bag o ****. if he is comming to a junction and dips the clutch it sometimes stalls. and its idleing really rough. give it a rev and wen i drop back down it will stall. hes got the eml light on so i decided to do the code read pedel test thing. this is what it came up with.
    0036 heater circuit -
    0704 clutch switch - assume this is why the cruise control doesnot work?
    0170 fuel trim malfunction bank 1 - not a scooby what that means!
    0136 02 sensor circuit malfunction bank 1 sensor 2 - lambda sensor faulty?
    1565 speed control switch out of range high - not a scooby again.
    any help in getting his car running smooth again would be great.
    West
    Although i ain't had a petrol for years, my brother had very similar symptoms on his vec b, if it were me i'd replace the crank sensor & take it from there... it worked for him.
    Nov 2010
    BRECHIN
    cheers for that, would this be the right one?
    http://cgi.ebay.co.uk/Vauxhall-Crank...#ht_1232wt_905
    West
    yeah that's the correct part no "9115115"
    Nov 2010
    BRECHIN
    cheers for that will order it up and shove it on, go from there. still a little worried bout this "fuel trim malfunction" error sounds expensive
    West
    the problem is 0170 covers a wide load of possible causes:
    o2 sensor & or connectors
    Maf sensor
    cam or crank
    or possible air leak
    imo it's always best to start with the cheapest & most common first
    hth
    Engine : 1.9 CDTi
    P0170 is long term fuel trim too rich.
    The ecu is trying to richen up the mixture due to a lean running engine and has reached its limits.
    Check for air leaks or it could be an air mass meter at fault.
    If you had an oscilloscope you could check the afm.
    Nov 2010
    BRECHIN
    i did mention to him about the maf so he put a new one just last week but no difference to the way it runs
    Nov 2010
    BRECHIN
    also he sprayed a tin of butane gas round the engine bay while it was running to see if the engine note changed at all searching for leaks. prob not the best way but to no avail will try the crank sensor, if i can find it and put a new one on.
    Nov 2010
    BRECHIN
    just looking to find the location of the crankshaft sensor. cant find it. i assume its easy to change and not hidden somewhere stupid?
  1. Father request for 11 yr old son, anyone help?
    By rob warrington in forum General Chat
    Last Post: 29th August 2012, 21:38
  2. a proud father
    By myelite150 in forum General Chat
    Last Post: 8th October 2010, 23:42
  3. Luke, I am your father
    By Keith Fusco in forum General Chat
    Last Post: 5th June 2009, 17:46
  4. My Father in Laws X-Type
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 8th April 2009, 19:50
  5. Father and Son
    By fenderguitar in forum Quick Photo Album
    Last Post: 21st May 2008, 16:26
