Thread: inner tie rods
    Aug 2010
    herts
    Question inner tie rods
    anyone changed there own inner tie rods as i done mine today and got the parts from vauxhallworldparts but when i got mine off the car they have grooves each side of the thread but the new ones have no grooves, also have a hole at the bottom of the thread,what are the grooves for,any help please.
    Mileage : 000
    Several members on here have done theirs. Hopefully one or two of them will read this thread and be able to give you an answer.
    Aug 2010
    herts
    hope so
    Aug 2010
    herts
    anyone please!!!
    May 2008
    newcastle
    the grooves down the length of the threads are to stop any potential pressure being trapped in the joint between the rack & tie rod when tightening it fully home as you are screwing the tie rod into a blind hole, if i remember correctly when i did mine the replacement ones didn't have grooves in them either. it's nowt to worry about.
    Aug 2010
    herts
    thanks john.
    scotland
    that is a 'relief cut ' , any crap/excess grease etc will enter the groove rather than fowling up the thread .
    also the hole will be for machining purposes ie... to hold the thing in place while its being threaded so it does not deflect and furk up the thread tolerance .
  1. Which inner tie rods?
    By Ian-Highlander in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2013, 19:41
  2. Inner Tie Rods
    By Stevie76 in forum Suspension, Wheels & Brakes
    Last Post: 4th April 2012, 20:30
  3. tie rods
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 21st November 2011, 20:09
  4. Track Rods
    By biggsa in forum Suspension, Wheels & Brakes
    Last Post: 4th June 2010, 20:27
  5. Tie Rods
    By smithi in forum Suspension, Wheels & Brakes
    Last Post: 3rd December 2007, 15:11
https:www.vectra-c.comforumshowthread.php127271-inner-tie-rods
