Results 1 to 3 of 3
Thread: Loss of power
    Luton
    Default Loss of power
    Hello Guys. Newbie here. i have a 2003 signum 2.2 petrol. it has been losing power briefly then kicking back in. it feels like it has lost some power generally overall. the engine managment light was coming on and the little engine symbol to the right of the dash. took it in and the guy said it was showing misfire on cyliders 1 and 4 and a new coil pack would fix it. £180 later the problems still there. any tips please?
    Bristol
    Vehicle : CDTI 150
    Did you check/replace the plugs. If a plug has a large gap the extra energy required to jump the gap can take out a coil pack. Can also be due to the ECU being faulty.
    Main tip is get your £180 back as the fault is no different!!!
    Luton
    they said they had replaced the plugs as well. the garage is usually quite reliable.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. loss of power
    By STRETCH2009. in forum Engine & Drivetrain
    Last Post: 8th August 2012, 18:44
  3. Power loss HELP
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 28th July 2012, 12:34
  4. 2L DTI '53 Loss of Power
    By BigTunz in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 17:27
  5. loss of power
    By philly in forum Engine & Drivetrain
    Last Post: 11th May 2009, 07:21
