Thread: Parking sensors
    Sheffield
    Default Parking sensors
    Hello first post and I think I originally posted in the wrong section so sorry if this has been covered before.I own a 2004 Vectra 2.0DTi Elite and the parking sensors have just stopped working.When I put the car in reverse a P))) comes in the window under my rev counter.It also comes on if I press the sensor switch near the CD player.I'm assuming all the sensors can't just fail so is there another reason for this to happen?
    Thanks in advance
    Paul.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    It only needs to be one sensor failed to shut the whole system down on the factory fit ones. I had exactly the same problem with mine and a quick tech2 session discovered which one was faulty (rear passenger side in my case), I replaced that one sensor and it all works fine again.
    You need to get someone to check the system with Tech 2 for you, either pay a dealer to do it or see if anyone on here is in your area that has one. That will tell you the problem sensor(s) and then get yourself on Ebay and pick up a replacement (they're a LOT cheaper on Ebay than at the dealers).
    HTH
    Sheffield
    Cheers!
    I'll have a ring around
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    I replied to your other thread regarding this, where abouts in Sheffield are you? I may be able to spare 10 - 15 minutes over the weekend, I should be able to read the codes to find out which one has failed.
    PM me.
    Full Member Robsey's Avatar
    North East Cheshire
    24 Post(s)
    Trim : Energy
    Mileage : 131,000
    I don't think the diagnostic tool will tell you exactly which sensor has failed... it will propbably just give a sensor error message / code.
    But the diagnostic Should tell you whether it is indeed a sensor or the control unit itself...
    Could be something as simple as a fuse in the REC... at this point I don't which, (if any), or could be a connector has been knocked loose, or become dirty / corroded, therefore affecting operation.
  1. OE Parking sensors
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2012, 19:02
  2. parking sensors
    By happypostie in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2009, 02:04
  3. HELP parking sensors
    By lee11 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th December 2009, 13:38
  4. Parking Sensors! Help!
    By Schui1024 in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2009, 23:52
  5. Parking Sensors
    By Mick B in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 21:58
