Thread: Changing frm CCR2006 to aftermarket kenwood dvd player
    Oct 2010
    glasgow
    Default Changing frm CCR2006 to aftermarket kenwood dvd player
    Hey guys,
    Id like to ask for a bit of help, Ive had a search on the forum and ive came across this thread.
    http://www.vectra-c.com/forum/showth...ging+head+unit
    Basically what Im wanting to do is change my standard headunit (CCR2006) to an aftermarket dvd player, namely a kenwood one.
    Would anyone be able to tell me what items I would need in order to keep everything else in working order?
    Thanks very much in advance
    Mo
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    You will need a vectra fascia plate, a cage, ariel connector, iso connector block cable, and steering wheel adaptor if you want the steering controls to work. some shops do offer double din fitting kits for £50 which gives you the cage, fascia plate, iso connector block and aireal connector. then all you would need to buy separate is the steering wheel cable. It is the better option if you can get a double din fitting kit as it will work out alot cheaper. A place near me called 'in car emporium' sells them £50, google them, I think they do a postal service. hope this helps mate.
    Oct 2010
    glasgow
    Ive removed the radio connector from the dvd player. It wouldn't fit in my previous car and I barely listen to the radio so wasn't too bothered ha! I can get the fascia plate for £6 from a local shop. is the cage and iso block really that expensive
    I had a glance at the option of fitting an aux input into the standard head unit, would this be possible with my head unit mate?
    Chelmsford
    I took mine out, removed the cover and front plate, then put a normal cassette adaptor into the tape deck. I threaded the lead through the insides of the unit, then put the front and cover back on, with the lead hanging out the back. Then I put it through a hole I drilled in the coin tray below, so the 3.5mm jack plug hangs out.
    Now I just plug my ipod in, select Tape and Bobs yer uncle...
    Oct 2010
    glasgow
    Cheers for the idea mate. Would anyone know if there is another method
    Oct 2010
    glasgow
    Sorry, bump!
  1. Changing ccr2006 for NCDC 2013
    By bigwilks in forum Electrical & ICE (including SatNav)
    Last Post: 22nd October 2012, 23:36
  2. For Sale: Kenwood Kenwood DPX-503U Double Din CD / MP3 / USB player AND Fascia!
    By John LE in forum Parts for sale
    Last Post: 3rd December 2011, 13:49
  3. CCR2006 is going and aftermarket is going in.
    By saintdean in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2010, 01:41
  4. kenwood kdc-w3037a cd/mp3 player
    By vectragsi3.2 in forum General items for sale
    Last Post: 10th April 2009, 20:12
  5. kenwood double din dvd player
    By david-bell in forum General items for sale
    Last Post: 28th October 2007, 20:55
