Thread: Ticking Noise 1.8 VVTi
    Regular Member Exclusive BV's Avatar
    West Midlands
    Default Ticking Noise 1.8 VVTi
    Do any other VVTi owners get a slight ticking noise on idle?
    Its speed dependant and sounds a bit like tappets but it does not go away once it's warm.
    Seems to go completely if you take the revs past 1600 rpm
    Engine seems fine otherwise
    Skelmersdale
    Yer mate I do. When did you have it serviced last? Also you should change the oil and filter on these regular, (I do mine every 4k-6k miles). Nothin to worry about IMO.
    Oct 2007
    Ripon
    Mine does the same, coming from the fuel injector area on mine.
    How long does it take for your oil light to go out btw? Mine about 2/3 secs.
    No sign when revving
    West Midlands
    Goes out straight away tbh.
    Noise is still there if not louder.
    car is regularly serviced, the oil is like honey at the moment
    i guess it might just be the injectors but i use redex in every tank as well
    Mar 2011
    belfast
    i also have that problem, sound is more louder when just started in the morning then it goes away. dont think its something to get worried about if the car is running ok, just keep checking your oil level and top up if needed. ....on another note has your car ever gave up a fault code of = p0014??? and if so, what does it mean???
    Regional Organiser - East Region whiskyno7's Avatar
    norwich
    15 Post(s)
    Vehicle : vauxhall signum
    Trim : 2.0t
    Engine : chipped and remapped
    Year : 03
    Mileage : 100k+
    Quote Originally Posted by Exclusive BV View Post
    i run mine on v-power petrol the car sounds and drives a hell of a lot better. i used to put red-x in but most petrol has cleaner in it anyway
    it say's it all
    Oct 2007
    Ripon
    Looking around I see the code as P0014 B Camshaft Position - Timing Over-Advanced or System Performance (Bank 1).
    Any idea what it means?
    Not done the pedal test yet but will try later today.
    Mine will give a very slight rattle first thing, normally only when cold (around 5-6c), ticking nose seem to come from the rear of my engine as you look at it from the front, around the injector area. No sign of it when revved.
    The oil light stays on for 2/3 secs when starting after a small period of being idle, again going through threads it does seem the norm for a few vvt's, one thread says they tried a few at the garage and they were all the same.
    Warranty valid till end of year so will ask when next at vx.
  1. ticking noise when air con on.
    By philc1210 in forum Engine & Drivetrain
    Last Post: 30th July 2011, 20:42
  2. ticking noise
    By tyler boy in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2011, 21:07
  3. Ticking noise
    By trickyjacks.4 in forum Engine & Drivetrain
    Last Post: 23rd February 2011, 15:33
  4. Odd ticking noise
    By Big Sig in forum Engine & Drivetrain
    Last Post: 20th June 2009, 22:54
  5. Ticking noise
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2007, 19:08
vectra c 1.8 slight ticking from engine
ticking noise on a vauxhall vvti engine
vectra c 1.8 tapping noise
vectra c petrol 1.8 vvti engine ticking
vectra c 1.8 petrol injectors loud ticking
