Results 1 to 10 of 11
Thread: Steering issue
    Sep 2009
    middlesbrough
    Default Steering issue
    Hi iv got a 55 reg cdti Sri, iv just been out and when I approached a right hander before a roundabout the steering felt heavy and like it wanted to go in a straight line, quite scary lol, I then threw it into another corner to see if I could re create the problem but it was fine, I thought maybe it was just the road surface but the steering does seem to be going stiff then loosening up, do vectors have a system where the steering gets heavier at a certain speed? Cheers
    Apr 2009
    nottingham
    Finally someone else with the same problem as mee lol mines been like it for ages took it to the garage and they told me it was the strut top bearing but i didnt belive them lol i had a look at it and it seems fine really should get it sorted though to be honest it gets worse in cold weather or in a morning or when its been stood for a while but after iv been driving for 8miles or so its fine again like it never happened... strange. Sorry i couldnt of been more help but just to let you know your not the only one lol you will have to let me know if you find out what it is
    Sep 2009
    middlesbrough
    I just hope it's not something serious like a steering rack, just picked it up today from the garage after £500 of work lol, what symptoms do u get from a rack?
    Regular Member Exclusive BV's Avatar
    West Midlands
    Get the battery and alternator tested guys
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Sorry to say lads, but i had the same symptoms, really stiff now and again, thankfully it was under a warrenty at the time from the dealers i bought it from, but it was the steering rack! think it cost the warrenty company quite abit!
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Just Got Coilovers Fitted In My Vec....I Got The Opposite lol..
    My Steering Feels Light As F***/Floating Even..Fitted New Strut Bearings And Drop Links As Well..
    Sep 2009
    middlesbrough
    What voltage should i be getting from the battery and how do I diagnose a faulty rack, was yours leaking? A battery or alternator would make sense when it's cold and im using all electrical items I suppose, Any idea how much for a rack and labour
    Apr 2009
    nottingham
    The battreys fine and not long had a new alternator so i dont think its that, however i do belive it could be the steering rack but how would it fix its self aftter a few miles, would it not be stiff all the time? and its not like a stiffness across the whole turning of the wheel just when travling in a straight line and then applying pressure to follow a bend in the road, it resists and so you apply more pressure and "DUNK" it frees up very strange lol iv had it in the garage twice and once they said you were low on fluid now its fine. what a load of...... that was. and the other saying it was the strut top bearing and that was fine so im just dealing with it atm. but would be very interested to find out what it is lol.
    Sep 2009
    middlesbrough
    Mine dosent appear to have done it again, I'm thinking it may of been an air lock as I had just come back from the garage or even the road surface or the tyres fitted, I'll keep an eye on it, I did look at steering racks etc just in case and ita not that expensive of that's the problem, I think I seen exchange remanufactured racks for about £120 on eBay and alternators for about £100, if you do find your problem let me know, cheers
    Regular Member mase56's Avatar
    oldham
    guys have you checked the power steering fluid level, i had a similar problem, pump was leaking and the fluid was mega low, steering felt fine while normal driving but as soon i tried a U turn for example it wouldnt have it, went really stiff like i'd just cut the engine out.
  1. Power steering issue.
    By frankieboy1 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd January 2013, 23:41
  2. Steering Rack Issue
    By willywoofter in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2011, 20:03
  3. Meriva Steering issue
    By D-S-Dave in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 22:57
  4. Power steering issue
    By MIAMI in forum Vectra C / Signum Troubleshooting
    Last Post: 21st September 2010, 21:05
  5. Steering Issue.
    By Danialj32 in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2009, 22:24
