Thread: still rattling!!
    Regular Member jofenan's Avatar
    nottingham
    Default still rattling!!
    ok....last week my cdti 150 started rattling from around the belt area...also noticed the guide wheel between the crank and air con was missing....got another wheel and new tensioner but this didnt help....replaced the bottom pulley tonight and the rattles still there....mainly on tickover....worryingly there's now a whirring noise coming from there too that i can hear when i rev the engine....when i remove the aux belt all the rattles and whirring noises go...only thing i can now think of is its something to do with the cambelt side of things....just think it would rattle all the time even with the aux belt removed...could the pressure from the aux belt be causing the crankshaft pulley to rattle???...this is its second engine and has done 45k (replaced under warranty)
    how easy is it to fit a new cambelt?...can get a kit from euro car parts for £111
    PRESTON
    Did you check the vibration damper pulley for play? this is what most people call the crank pulley and is held on with four bolts to the crank. They are made up of two parts, so try wiggling it in both directions to check for play. It might well be this rattling or maybe the clutch pulley on the alternator.
    nottingham
    thats the pulley i just replaced....i still hope its something attached to that belt....last week was expensive with the dmf going too!
    i didnt know the alternator could rattle like that?...how do i check it....am still thinking about the ac unit too....is it meant to make a metallic sound if i tap the pulley?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    remove the altonator belt and see if the noise stops
    PRESTON
    ahhhh!!!! it could be the aircon pump, have you tried switching the aircon on and off with the engine running? and if so does the rattle change note? The pulley on the aircon is i believe electrically operated, so when the air con is switched on, the pulley engages to drive the pump and when switched off, disengages and freewheels on the pump. It might well be that it's failing. I am insure of how you would check it any further, but i'm gussing it shouldnt rattle. Just another thought, if you were to get a shorter belt from the motor factors and by pass the air con unit, you can still run the car and see if the rattle goes away, if it does, then the ac unit beggered.
    nottingham
    the noise defo goes away when i take the belt off and my next step in the morning is to get a stethoscope!
    will see if i can pin point the sound either end,hope it is the ac as i dont need it just yet!
    Regular Member ONEMINUTESILENCE's Avatar
    Jul 2010
    Skipton
    Quote Originally Posted by jofenan View Post
    Mate see my thread about chirping. Is that the same noise?
    nottingham
    my noise is much more metallic....almost like a whacking a spanner on the engine block!
  1. Rattling radiator...
    Last Post: 10th March 2012, 23:02
  2. Rattling Speaker
    By Carl83 in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2011, 20:57
  3. rattling
    By SilVectra in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2010, 20:53
  4. Rattling vvt.
    By mattDY57 in forum Engine & Drivetrain
    Last Post: 8th June 2009, 19:57
  5. rattling noise
    By jaxouk in forum Vectra C / Signum Car Chat
    Last Post: 4th September 2008, 12:29
vectra c 150 crank rattle
