Thread: Key fob problem...
    st neots
    confused Key fob problem...
    Hi all,
    I just bought myself a 52plate 2.2sxi and am now having problems with the key fob not working properly. Key was working fine when I bought the car but now after owning it for a while I have now realised the problem.
    It works sometimes but more often than not absolutly nothing...I have replaced the battery and still nothing...???
    Starting to get a bit annoying as I am having to lock and unlock the car with the key and therefor keep setting the alarm off until I can get the key in the ignition barrel to switch it off...
    Any help you can give will be great.
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    it will be the micro switches in side the black buttons on the board inside the fob get some new ones and replace them I brought a new key on ebay and took it to a tv repair man to get the switches swapped over as the boards are tied to the alarm system
    hope this helps
    13 Post(s)
    Quote Originally Posted by markj23 View Post
    Not necessarily. It could also be the other common problem of a dry solder joint on the battery terminal. Easily solved with a soldering iron or a thin piece of card on top of the battery to make it press down harder when the 2 halves of the case are put back together.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    After you changed the battery did it lock/unlock with the fob?
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
vectra key fob not working in cold
vectra c key fob cold
