Results 1 to 10 of 11
Thread: Damp problems...
    Wales, UK
    Default Damp problems...
    What do you all suggest...
    Dont think Ive got leaks or anything, to be honest Im pretty sure its from the continued use of the car during the wet weather and snow thats soaked the floor....
    Its the drivers side, carpet feels ok, maybe a little damp but the sound proofing underneath is soaked. I found it when removing the plastic chassis number thing when hoovering around it.
    But, both the front and rear windows now get a lot of condensation forming on the insides.
    Any suggestions on what to do ?
    Thanks all,
    Mark
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    i have the same issue but i find its the rear window that's the worse to the point its soaking and i have to use a towel ... i have put it down to how well the doors are sealed when closed on my previous vec b i didn't have any issues . I read a post i think yesterday that a member has adjusted all the door locks by a few mm which has helped so this is something i`m going to look at doing on sunday
    as for the excess water try a wet and vac to soak it up or towels
    Wales, UK
    Yer, that wont help the situation, let us know how you get on with that.
    Problem is, its the lagging under the carpet. Impossible to get to without taking it all up and of which I guess, involved removing th seats ! argh ! lol
    Vectra-sport Admin
    Vehicle : VXD
    wet and vac is going to be the best option without taking the vec apart and a hair dryer or something
    Aug 2010
    Leeds
    Find the pollen filter under the plastic panel under the windscreen under bonnet, Remove this panel and you will see the pollen filter down below.
    Under the filter is a drain bung that gets blocked with leaves and muck and water has nowhere to drain to but gets in into your car and under the carpets.
    Simply stick your fingers through the drain bung to clear it and all will be well.
    Yours maybe just from the weather but do check the above asap.
    Wales, UK
    Thanks mate, yer checked all that and its all clear. My fault, think its to do with the weather to be honest. So annoying lol
    In the week, think ill take the trims off and lift the carpet - see what the score is.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    There's also another drain hole under the scuttle panel (Rain deflector) on the drivers side under the wiper mechanism..far right..difficult to see.. check that one as well...
    Wales, UK
    Quote Originally Posted by Tony W View Post
    Right didnt know that. That might explain the drivers side being wet... As I only thought the passenger footwell was affected when the drain hole was blocked.
    Will rip it all out Sunday I think, weather permitting of course
    Thanks all
    Wales, UK
    10 points to you. It was well and truly blocked. I didnt realise there was one on the drivers side aswell so thanks for that !
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
  1. Damp smell ?
    By m8wos in forum Bodywork & Interior
    Last Post: 10th January 2013, 19:34
  2. Damp gearbox, need some help!
    By Chip in forum Engine & Drivetrain
    Last Post: 13th May 2012, 23:10
  3. Damp Smell?
    By gaz1965 in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2012, 23:23
  4. Damp/ wall tie problems
    By sberrow in forum General Chat
    Last Post: 27th October 2010, 20:56
  5. Damp!!
    By ballan22direct in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2009, 23:17
