Thanks Thanks:  1
Likes Likes:  3
Results 1 to 10 of 11
Thread: Weird clicking noise from heater control or glove box
    Redcar
    Default Weird clicking noise from heater control or glove box
    Everytime I start the car I get these clicking noises from glovebox area or heater. not sure exactly :-(
    Regular Member wallace78's Avatar
    Dec 2010
    belfast
    think it will be ur pollen filter motor might have sumfin stuck on it r on the blink!!!
    Mileage : 000
    I don,t. I think the recirc" motor has lost a tooth. Does it make the noise when you press the recirc" button.?.
    If so you need to replace the recirc" servo. There is loads of info on this "problem" if you do a search for "say" recirc servo.
  4. Likes Matty2Fatty liked this post
  5. #4
    Regular Member mickg's Avatar
    High Wycombe
    just un plug it that what i have do thats the reccirculation motor. undo glove box i think is 4 screws and un pkug it. replacing about 60-70 quid.
  6. #5
    Nottinghamshire
    Has it just started doing it or has it always been like that? Does the heater system appear to work properly?
    I have the full climate control setup in my car and there's some clicking and whirring from behind the glovebox (audible but not hugely loud and nothing sounds like it's broken or stuck) sometimes when I start the car for a few seconds until the system has moved all of the heater system flaps to where it wants them. I occasionally hear it as well as I'm driving along as well?
    I think all of the mechanisms are much the same between the 2 systems but it's only the climate control setup that can move them all about when it wants to (in 'auto' mode).
    You could take the glovebox out (6 Torx screws) and press all the buttons and turn all the dials on the heater control panel and watch the various motors and levers turn. You should see if any are stuck or broken, or have cogs with missing teeth, etc.
  7. #6
    Nov 2010
    CHIGWELL
    Engine : 1.9 cdti (150)
    Mileage : 88000
    Sound like I have a similar problem, was getting a ticking noise when I open the doors and get in, and sometimes when I stop the car. Now happens every time a turn the recirc on or off for about 15 secs then stops. Even on a long motorway journey with recirc on most of the vents were not blowing warm. So what do I need to replace? Is it easy?
  8. Likes Matty2Fatty liked this post
  9. #7
    Oct 2017
    Scottish Borders
    Vehicle : Signums
    Trim : Elite / Exclusiv
    Engine : 3.0 V6 CDTi / 2.2
    Mileage : 102000
    Resurrecting an old post rather than putting up a new one. My car - 2.2 direct petrol with standard aircon and 4 speed blower motor - developed a weird noise on Monday and some of the symptoms sound similar to this post and a few other related posts.
    When I turn the ignition on, but before starting (I also have a diesel so am now in the habit of sitting waiting for the glow plug light to go out, even in the petrol!) I immediately get a loud clicking noise for seven or eight seconds. It is very loud (sounds like the fan is hitting the plastic surround) and clicks 2 or 3 times a second.
    If I turn the engine over the noise stops while the starter is engaged, but returns as soon as the engine is started. I thought at first it was the heater motor so tried starting with the fan blower on different settings but it made no difference. I also ejected the satnav disc, thinking it might be a sticking disc or faulty drive, but that made no difference.
    The heater, direction control of vents and aircon are working fine and the engine starts up right away and runs fine.
    I will try with the recirc switch on and off to see if that has any effect. But before I strip the dash and glovebox down, do the symptoms described above sound the same as those when the recirc servo has stripped teeth? i.e. clicking for several seconds every time the ignition is switched on but everything else functions as normal?
    If not, is there a control module behind the heater switch panel that might be the source of the loud clicking?
  10. #8
    Oct 2017
    Scottish Borders
    Vehicle : Signums
    Mileage : 102000
    Quick update - tried the car this morning and as soon as I switched the cabin recirculation button to the on position the clicking sound stopped. So servo must be the problem. Will investigate at the weekend to see if I can disconnect the wiring for the moment and look to make a permanent fix later.
  11. #9
    Regular Member Matty2Fatty's Avatar
    Mar 2014
    West London
    90 Post(s)
    Trim : Elite Estate
    Engine : 1.9 CDTi 16v 120 BHP
    Sounds like the recirculation motor, mine used to do it when you unlocked the car, the interior lights went out and when you pressed the recirculation button on the ECC.
    Think it was £10 for a new one (from a Saab I got mine from, but same part number) and took about half and hour to swap over. The fiddly bit was undoing one of the screws that held it in as space is tight up under the dash. I did do a video on here somewhere, so shall try and find it...
  12. Likes fatfred liked this post
  13. #10
    Apr 2012
    Paignton
    Vehicle : Vectra C Estate
    Engine : 1.9cdti auto
    After taking the recirc servo out, you will usually find that if you dismantle the unit (quite easy), you can remove all the white cogs, you will find that the big cog has probably lost a tooth or two. if you can drive out the metal shaft and remove the big cog wheel, you should be able to turn this by 180 degrees, and then drive the shaft back in. 20200831_124013.jpg You will probably find it easier to replace with shorter cross head screws as they are a sod to do up.
  14. Thanks soulman thanked for this post
  1. Heater clicking noise again
    By Bamber in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd July 2012, 22:40
  2. Heater Control Clicking/Tapping
    By pauldellboy in forum Electrical & ICE (including SatNav)
    Last Post: 21st May 2011, 20:22
  3. Weird Clicking noise
    By Bloicy 3.2 V6 GSI in forum Electrical & ICE (including SatNav)
    Last Post: 18th June 2010, 22:29
  4. clicking noise (assuming behind heater control pannel)
    By 9tjc in forum Electrical & ICE (including SatNav)
    Last Post: 1st December 2009, 23:11
  5. clicking noise from behind glove box???
    By mick 1986 in forum Electrical & ICE (including SatNav)
    Last Post: 28th May 2009, 12:58
https:www.vectra-c.comforumshowthread.php127137-Weird-clicking-noise-from-heater-control-or-glove-box
vectra c heater clicking
vectra heater clickingvauxhall signum clicking noisemy heater is clicking on vauxhall vectraWhirring and clicking noise when car heaters are on vauxhalli have a clicking sound in the back of my vectravauxhall vectra 2.2 direct problems clicking from glove box clicking noise coming from my vauxhall vectra c behind the heating controlsclicking noise in glove compartmentvauxhall zafira heater noisevectra c noise from glove compartmentvectra c recirculation motor unplug socket clickingtapping noise behind car heatersvauxhall vectra c heater clicking ticking noise stops when doors locked 2009 insigniavectra heater controlsinsignia heater not working clicking noisevectra c clicking sound glowebox2004 vauxhall signum 2.2 direct clicking noise coming from under bonnet after unlocking the carastra recirulating making clicking noisevauxhall viva problem wkth heatign system clickinginsignia clicking npise from glove boxvectra c loud clicking from glove boxvectra short rapid knock glove box
