Results 1 to 10 of 21
Thread: Frozen windscreen
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Default Frozen windscreen
    came out to the car this morning and frost was all over the car so got in the car to get me scraper and to start the car and then got scraping only to realise that the frost didnt seem to be coming off, then i realised that there was frost on the inside of the screen as well! took ages to clear the screens. i had planned on cleaning the car today and sticking the floor mats throu the washing machine as they are really grubby only to realise that the passsenger mat is sopping wet as well as the carpet and i mean sopping! grrrrrrr
    so off with the wiper arms, and the scuttle shield to find the scuttle full of water and the pollen fillter soaking, found the drain plug to be totally blocked so cleaned that out and dried the lot out and refitted everything including a new pollen fillter, job done but how can i dry the carpets out quickly as i dont wanna leave the engine running with the heaters on not with the price of fuel lol
    and i find it hard to believe that vx only rely on the one drain hole to drain water away unless there is another cos i couldnt find it no doubt i will have problems with either the heater motor now or the heater motor resistor!!! as as electrics dont like being soaked
    grrrrrrrrrr
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    sorry to hear but maybe a fan heater left in your car or open all the doors and boot and leave it or get misses hair dryer and use that apart from that i dont know or when you do drive it have the heater on the floor only apart from that i dont know sorry few ideas there tho
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    suck as much as you can up with a wet vac
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    how close to your house is the car parked? i noticed earlier my neighbour has a dehumidyfyer in his car plugged in through a outdoor extension lead!
    Sep 2010
    potato sack full of silica gel?
    Sep 2010
    in a box
    Quote Originally Posted by chewy71 View Post
    would work a treat that
    Jul 2009
    The Rift, Cardiff
    There is another drain on the drivers side, its in the corner by the wing/windscreen. I had to remove the wiper motor and linkage mech to give it a proper clean out as it was compleatly blocked.
    swansea
    Newspaper, and put the mat back on top, you'll be surprised how much water it will suck up.
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    I had a same problem mate, Not the wet carpets etc but my heater motor started making a squeak sound so I checked location and found my scuttle drain blocked and pollen filter wet. So I put one and one together and thought water must have got into the heater motor. That was 2 days after getting the car, so what I did was get some of that lubricating spray that drives moister away on electrical stuff, I thnik wd40 does something similar. But I got this of my bro in law who is a mechanic.
    What we did is put the heater fan on full opened all doors and sprayed the motor behind the pollen filter with this stuff, left it running for 20 mins with fans on full (fumes from spray). 5/6 weeks later and not even a little squeak etc and all seems fine.
    I will try and get the name of the stuff we used.
    Are you VXR Enough
    13 Post(s)
    Quote Originally Posted by scotty84 View Post
    cheers fella i will give that a try
  1. BMW - Frozen Paint
    By spoons in forum The 'Off Topic' room
    Last Post: 13th July 2012, 12:51
  2. frozen products
    By paul.sessions in forum Detailing and Car Care Discussion
    Last Post: 17th February 2012, 17:10
  3. frozen door
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2010, 20:22
  4. Frozen diesel ?
    By hartley in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2010, 18:42
  5. hi from the frozen northeast
    By coastguard in forum Introduce yourself.
    Last Post: 15th February 2010, 09:09
