Thread: What is "MAF or VAF A Circuit Malfunction"?
    Mar 2007
    Chatham, Kent
    Default What is "MAF or VAF A Circuit Malfunction"?
    I've just had the megine management light come up on my Vectra and reading the code, it indicates a P0100 - MAF or VAF A Circuit Malfunction.
    Does anyone know what that means in layman's terms!
    Essex
    28 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    Mass Air Flow .its a sensor coming off of your air box ..
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    cylindrical thing between airbox and inlet manifold
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    you get a can of maf cleaner or Electrical contact cleaner from Halfrauds, costs about £4 ish.
    Unscrew the MAF from the air feed pipe and disconnect the sensor wires. Spray all over the MAF the important parts are the small wires that look they belong in a light bulb, take care with those, when done then wipe it off, leave to dry for about 45 minutes then reseat back on the air feed pipe near your mengine, wait another half hour and then go for a drive.. Its rarely necessary to need to replace the MAF, a nice clean with that spray or a bottle of Isopropryl alcohol poured into a plactic bag to immerse the sensor will do the trick.
    You may need to clear the code first, but if you can't then it should clear itself after a successive amount of non fault engine restarts..
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. P0621 - Generator Lamp "L" Control Circuit Malfunction
    By danielk in forum Electrical & ICE (including SatNav)
    Last Post: 20th June 2012, 20:57
  3. P0380 Glow Plug/Heater Circuit "A" Malfunction
    By sinless in forum Vectra C / Signum Troubleshooting
    Last Post: 9th March 2012, 21:38
  4. PO409 exhaust gas recirculation "A" circuit
    By billy_wiz in forum Y & Z30DT Specific
    Last Post: 6th February 2012, 09:13
  5. O2 Sensor Circuit Malfunction
    By marcdale in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2009, 21:21
maf or vaf a circuit malfunction
maf or vaf circuit malfunction
Astra 1.9cdti twintop fault code po100
vaf a
vaf a
what is maf or vaf a circuit malfunction
vaf.awhat is maf and vaf on vectra cmaf or vaf a cktmaf or vaf a circuit is malefunksjonevaf a circuit malfunctionopel vectra c vaf vaf circuit malfunctionwhat is maf or vafV A FA
