Thread: Squeaking heater fan
    Sep 2009
    ipswich
    Default Squeaking heater fan
    Well mines been squeaking like a banshee wailer since I bought the car. Been driving me up the wall... especially when wanting to use air con. But I have never wanted to spend £300 on a new one (supllied - not fitted).
    I was just having a look at the pollen filter tonight and cleaning out the moisture shute and when I took out the pollen filter I saw the heater motor is right near the openning. I was able to lift the fan up about 3mm with a long screw driver in my left hand and stick my WD40 (using the small can which will go in openning) straw in the gap. I pumped in some oil and worked the fan round and hey presto!!... silent fan.
    Happy days :O)
    Regular Member *enery*'s Avatar
    Mar 2007
    glasgow
    ideal..mines has started chirping on setting two so il have to go about this:-)
    Regular Member Maxim007's Avatar
    Jul 2009
    Bistrita
    yesterday mine start chirping too....
    but mine sound hears from back of center console...(somewhere behind the stereo unit...but little deeper)...and sounds like something would rub the heater blades...
    So I will check later if my heater motor is lifting up...like waterbourne says...
    And will try to spray some WD40 in there....
    Regular Member Craig1985's Avatar
    harwich essex
    Mine did it, I turned fans on full but closed the vents and squirted sillicon spray in the vent behind the pollen filter. This sorted it and it been fine since
    stockport
    Thumbs up
    Quote Originally Posted by Craig1985 View Post
    Aim for the centre of the fan unit,(where the bearing is),and you shouldn't have any further probs.FELIXX.
    Oct 2010
    London
    Make sure there's no water running into it from under the scuttle panel either, check the drains and make sure they are clear.
    On my old Astra the seal between windscreen and scuttle became rotten so water leaked through it and into the blower motor, breaking it!
    And if it does die just get a new one off of fleabay for £50
    Full Member
    May 2007
    Blog Entries
    1
    Default WD40 v Silicone Spray Lubricant
    Just to report that I tried WD40 into the top of the blower motor first of all, and the squeaking improved for a few days but was gradually reappearing. I then tried Silicone Spray and that seems to have done a better job.
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    mine sometimes makes more of a creaking noise thana squeeking one .
    Dec 2011
    Seaham
    Try some motorbike chain lube s it also has a bit of grease/wax in it and will not dry out like WD40
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 167340
    Quote Originally Posted by Ben50n View Post
    thanks benson i might try chain lube
    Feedback Score: 0 reviews
    Squeaky blower motor
    mine has started squeaking does wd 40 work or make it worse?
    what have you used ? and works well. anyone
    anybody fixed theres and the squeak has never come back?
  1. Squeaking/odd noise
    By DaKemps in forum Suspension, Wheels & Brakes
    Last Post: 19th June 2012, 23:01
  2. squeaking heater!!!!
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2009, 12:10
  3. squeaking brakes
    By willoftoon in forum Suspension, Wheels & Brakes
    Last Post: 14th June 2009, 15:10
  4. aux belt squeaking.
    By john1 in forum Engine & Drivetrain
    Last Post: 21st April 2009, 20:32
  5. Another Squeaking Noise
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2007, 07:54
vauxhall vectra squeaky heater fan
vauxhall vectra squeeky fan
vectra c heater squeaking
squeaky heater fan vectra c
astra squeaking noise heater
vectra blower fan squeaking
vectra c grease fan
Astra g blower motor squeal
signum air con squeak
heater fan noise vectra c
vectravair vents making creaking noose
insignia heater fan noise
the heater on my vectra is making a squeaking noise when on
why does heater motor on vauxhall vectra 57 plate squeak
how to fix noisy vectra heater fan
squeaky fan vauxhall vectra
vectra c squeaky fan
vectra c heater blower squeaking
vectra c noisy heater fan
blower fan squeaking on vectra
vauxhall vectra c air con squeaky
2006 vauxhall vectra 1.8 sri squeeking from heaters
astra g how to lubricate interior fan
